Integrated Tail light
Old Aug 6, 2008 | 06:42 PM
SuperMike's Avatar
SuperMike is on a distinguished road
This forum is great. Y'all help me a lot with my questions and have saved me $$ already so thanks. I ordered an integrated LED tailight. It is supposed to be a plug and play easy swap. Will I have any problems with the current turn signal relays or should they work with this mod?
Old Aug 6, 2008 | 07:08 PM
blupleous's Avatar
blupleous is on a distinguished road
you will need resistors when using led's or they will flash fast. my "clear alternatives" came with everything needed
Old Aug 7, 2008 | 06:44 AM
SuperMike's Avatar
Resistors? Hmm maybe this is beyond my scope but how hard is it to install these?
Old Aug 7, 2008 | 07:05 AM
supertrooper's Avatar
supertrooper is on a distinguished road
it really easy to install. most of the resisters i have seen for bikes have some wire sticking out the ends that you use wire connecters to put it inline with the turn signal wire. if you like the fast flash, dont install them.
Old Aug 7, 2008 | 01:46 PM
SuperMike's Avatar
Thanks for the word. I wonder if these can be purchased at advance or some place like that. Guess I will just have to see. So long as it is an obvious blink and not too close to looking like its on all of the time, I may leave it alone. Either way it is gonna look sweet with the led and smoke lens
Old Aug 7, 2008 | 02:35 PM
blupleous's Avatar
here is a link. oops! did i say resistor, i think it is a diode. i have not looked for them at local auto parts.
http://www.denniskirk.com/jsp/produc...t210002&mmyId=
not sure if the price is good
Old Aug 7, 2008 | 02:46 PM
filter69's Avatar
Thats Mr Dill hole to you
Yea diode's will stop back feed but you still have to install some resistors to up the load in the flasher to slow the flash. Really depends on what tail light kit he ordered some have "Resitor Load" built into them so you only need the diode's. will just have to wait and see what he gets.
i gotta get rid of my ugly as* stock turn signals come to think of it.....
Old Aug 7, 2008 | 04:43 PM
timdske's Avatar
timdske is on a distinguished road
If your buying a Clear Alternatives tail light assy, it comes with the resisters.
I installed one on my SH. It was very easy.
Old Aug 7, 2008 | 04:45 PM
timdske's Avatar
It's a resister, not a diode.
Old Aug 7, 2008 | 04:54 PM
filter69's Avatar
Well all seem to have a problem spelling resistOrs im guilty of it also not resisters <- thats the southern spell'in ov' it
Hell im stuck at work why not ....
Old Aug 13, 2008 | 01:50 PM
Zedicus's Avatar
Zedicus is on a distinguished road
im a bit late to this post but if yur still needing help you can get a digital blinker relay off ebay for little to nothing. clips in where the stock blinker relay was and makes it so u can run all the leds u want and they blink the normal speed, plus it doesnt make the load clicky noise.
and it was prolly mentioned but a trailer light integrator makes a great blinker integrator for motorcycle tail lights.
Old Aug 13, 2008 | 03:28 PM
lowell's Avatar
Simi Valley, CA
lowell is on a distinguished road
http://clearalternatives.com/index.html
Old Aug 8, 2014 | 07:46 AM
supertim996's Avatar
supertim996 is on a distinguished road
Mine came with the two resistors, it doesn't flash fast, but I left my two small aftermarket turn signals hooked up as well. My situation is that eveything lights up but when I apply the front or rear brake I get nothing. If you put the stock bulb in it works
Bearshawk
Aug 7, 2014 05:46 AM
Mattaua
Mar 16, 2011 06:58 PM
Mattaua
Oct 27, 2010 04:07 PM
Hawk2445
Jun 24, 2009 06:54 AM
seaton001
Mar 19, 2007 05:46 AM
