I'm sitting on the side of the road...
Old Sep 16, 2013 | 02:18 PM
thedeatons's Avatar
Was going just fine, 60mph down the road, when i hear this terrible clatter from the front of the bike... I think i know what it is... I stay steady on the gas, and slowly roll off the throttle in 6th gear. I let the bike coast all the way down to fast walking speed, staying on the gas a bit, then i shut it down, and it bumps to a stop.
I'm guessing i saved it, and it will probably only need a cct swap, though i'm not entirely sure...
I'll try to get it done asap, then report back
Thanks for all the threads explaining exactly what to do when the noise is heard.
On my iphone, waiting for my ride...
James
Old Sep 16, 2013 | 03:05 PM
Wicky's Avatar
https://www.superhawkforum.com/forum...b-mccts-30961/
Well you knew in August that you were sitting on a timebomb!
Check that you don't need new valves, piston, head etc....
Old Sep 16, 2013 | 03:35 PM
thedeatons's Avatar
My posting wasn't so much in surprise, but more in humor... Cracking open the valve cover now.
James
Old Sep 16, 2013 | 03:48 PM
Old Sep 16, 2013 | 05:01 PM
Squid's Avatar
^ Hehe. I hope for the best when you open her up.
Old Sep 16, 2013 | 05:22 PM
HRCA#1's Avatar
Well I wouldn't worry about the piston so much but obviously you could have dinged the valves probably only the Intakes. You wouldn't have trashed the head either unless you broke the valve guides, which can be replaced but most dealerships/shops either don't know how to do it or don't want to.
In the best of all possible worlds you just need a cct (forgive me Voltaire).
Old Sep 16, 2013 | 06:17 PM
jerryh's Avatar
Drill out the ccts I sent and install a cap screw
Old Sep 16, 2013 | 06:40 PM
If you're talking about a set screw in the side of the CCT, doesn't that still leave the spring exposed to failure? As in the worst of both worlds... a non automatic CCT that can still fail? Or are you talking about something else?
Old Sep 16, 2013 | 07:06 PM
jerryh's Avatar
I'm taling about converting oem to manual. Drill and tap
Old Sep 16, 2013 | 07:37 PM
thedeatons's Avatar
Drill & Tap = Done. I'm getting the acorn nuts welded on tomorrow. I'll have another set ready to go soon too, if someone needs them.
I reset the cam chain/gears tonight, everything now matches (they skipped a few teeth when I was turning the flywheel nut, but never opened the valves during that time because of valve spring pressure).
Gonna install the manual cam chain tensioners tomorrow night, then compression test front and rear, to see if any damage was done. It was the front spring by the way, broken like all the other pictures, just a few coils in from the end.
Praying for a speedy recovery, and good compression...
James
Old Sep 16, 2013 | 11:54 PM
jerryh's Avatar
James
Damn oem cct's
Old Sep 17, 2013 | 05:47 PM
thedeatons's Avatar
Cold Compression (with no oil added to the cylinders):
Front - 140psi
Rear - 142psi
God has blessed me.
Once again THANK YOU for all the posts telling me what to do when the CCT spring breaks... In case anyone missed it:
1) Don't pull in the clutch or shift!
2) Slowly back off the throttle until it decelerates to a walking pace then shut the engine off (with clutch still out and bike in gear)
3) Keep it upright until the bike stops
James
Old Sep 17, 2013 | 10:02 PM
Damn, you got LUCKY! Get 'er back on the road.
Old Sep 17, 2013 | 10:17 PM
thedeatons's Avatar
I also found a missing vacuum cap on the front carb's T.... Crazy.
Should be running tomorrow after work. I'll ride it to church tomorrow night and report back.
I still have to fine tune the MCCTs though. Just set them Finger Tight + 1/4 Turn for now.
James
Old Sep 18, 2013 | 07:33 AM
insulinboy's Avatar
James
Thats too tight. Should be just till you can feel pressure on the adjuster then back off 1/4 of a turn
APE Manual Cam Chain Tensioner Installation
Old Sep 18, 2013 | 03:50 PM
thedeatons's Avatar
Really? I thought I read that was what you do... I don't have any squeal noise or anything...
Okay, I will check it out either later tonight or tomorrow. Gonna do a 50 mile ride tomorrow night.
It started right up today
James
Old Sep 18, 2013 | 04:02 PM
James
No noise or squeal or lack of power= probably fine. I wouldn't worry about it. May not hurt to check under the valve cover or tune them more, but "finger tight" is so damn vague I would hesitate to call it correct or incorrect over the internet...
Old Sep 18, 2013 | 04:17 PM
thedeatons's Avatar
I agree 7moore7... I had planned to do what Tweety suggests and adjust them while listening to the engine... Eventually I'll get to that
James
1drummerdan
Aug 5, 2011 10:38 PM
StoneJrW
Aug 5, 2008 04:25 AM
Linkz
Apr 21, 2008 11:18 AM
Dusty B
Apr 15, 2008 06:35 PM
Yardstick
Dec 25, 2006 08:18 PM
