If you know what the item next to the back pipe of the ingen
Old May 21, 2005 | 12:03 AM
mrjakeanderson's Avatar
mrjakeanderson
Please help. I was takeing off my pipes to paint them. I took off the back pipe, but to make it easier I took that 2.5inch thing off thats next to it(right side) so I could get a better opening to the pipe. But what the hell is it ? It doesnt go back in. Its the long metal thing you see on right side if your looking at the spring/pipe to ingen. Help...??
Old May 21, 2005 | 05:18 AM
yellowvtwin's Avatar
yellowvtwin
cam chain tensioner you need to make a locking tool to install it easily .You make it out of 1mm plate there is a pic the the workshop manual if you dont have a copy there is a PDF download link to it on www.ozfirestorm.com (probably one here )
Old May 21, 2005 | 06:03 PM
mrjakeanderson
Re: If you know what the item next to the back pipe of the i
I checked on http://ozfirestorm.com but coudnt find anything. Please help im scared I can feel inside and it seems like the peice I took out has an arm that holds something in place ? in takeing it out did stuff move that wont go back into place without takein apart the ingen ?
Old May 22, 2005 | 01:09 AM
yellowvtwin
I posted a request over at www.ozfirestorm.com for some pic's give it a little time one of the fella's will post up the info needed from there PDF copy .Its in tech stuff just chuck in a post to let them know you are checking in for help
Old May 22, 2005 | 02:15 PM
yellowvtwin
ok check www.ozfirestorm.com in tech stuff in the help for an O/S stormer thread there is a link there
Old May 25, 2005 | 04:58 PM
mrjakeanderson
Jeez, okay I found out whats up... People kept saying. "take the back screw out, so they spring wont be comprest, makeing arm extend" The screw has about two inches down a flat head acssesable head that when turned pulls the arm in!!! problem solved. thank you all....
Old May 25, 2005 | 09:05 PM
NOrrTH's Avatar
Gotta hate spring loaded mechanical contraptions for making one soil one's self.
motojoe
Sep 8, 2016 03:05 AM
reaper
May 12, 2013 04:54 PM
oicdn
Jan 5, 2008 02:05 PM
senecagreen
Mar 28, 2007 06:40 AM
