ICM Yellow liquid Leak
Old May 11, 2017 | 12:23 AM
ae29's Avatar
ae29 is on a distinguished road
hi,
Can anybody enlighten me what that yellow liquid in the Ignition Control Module is/called? Have mine leak out and that sticky yellow stuff is a mess and hard to clan.
I want to get it re-filled before I epoxy and seal the ICM back up.
I do want to get it at the shop but at least armed with the correct name else the vendor will start giving me yellow plegm instead lol
Old May 11, 2017 | 04:36 AM
Wicky's Avatar
Blinker fluid should work for the ICM
Old May 11, 2017 | 07:34 AM
Synthetic will make your spark plugs slip.
Old May 11, 2017 | 07:45 AM
This is the corollary to letting the smoke out of the wiring.
Old May 11, 2017 | 11:24 AM
Originally Posted by ae29
hi,
Assuming for just a moment this is not a joke post, and your question is real.....
The electronics of the Ignition control Module are "potted"
Potting in electronics is a process of filling a electronic assembly with a solid or gelatinous compound for resistance to shock, vibration, and for elimination of moisture and corrosion. Potting material is commonly Thermosetting plastics or silicone rubber gels.
If the case is damaged, cracked, rubbed though and potting material is leaking out, you can seal the case with epoxy or RTV for now , but Id be looking for a replacement unit
E.Marquez
Oct 16, 2015 07:12 AM
jscobey
Apr 25, 2014 02:03 PM
MOONSHIELDhr
Oct 29, 2010 03:30 AM
Circuit_Burner
May 6, 2009 10:44 AM
