I need a new clutch what do I need???
Old Feb 21, 2008 | 10:02 PM
kevinmeller's Avatar
kevinmeller is on a distinguished road
I need to replace my second gear and I know since I have 16000 miles on my 2000 hawk that I should replace my clutch. So what do I need to replace the clutch is this all http://www.motorcycle-superstore.com...awk-Parts.aspx or is there more???
Old Feb 21, 2008 | 10:42 PM
Syclone's Avatar
Boosted
I think if you're going to the work of replacing disks, you could probably do springs while you're in there.
Old Feb 21, 2008 | 10:51 PM
ok so those will work??? and then I should add http://www.motorcycle-superstore.com...awk-Parts.aspx and then thats all
Old Feb 21, 2008 | 11:27 PM
Syclone's Avatar
Boosted
That should do it, though I've never done the clutch on the SH...
Old Feb 21, 2008 | 11:42 PM
killer5280's Avatar
Are you sure you need to replace the clutch discs? A clutch that's not abused can last a LOT longer than 16,000 miles.
Changing clutch discs is a pretty simple job and can be done any time.
Old Feb 22, 2008 | 03:53 AM
Don't forget a new engine cover gasket...last time I needed one they were backordered and took almost two monts to get from the damn dealer...
Old Feb 22, 2008 | 09:02 AM
ok so the more i read i am seeing that I may have this bent shift fork problem as I have the popping into nutral from second gear. But as much as i have read on the subject its not clear if I am replacing second gear still or just the shift fork, dog, and drums????????????????
Old Feb 23, 2008 | 10:33 AM
Motohead's Avatar
Motohead
Not sure on the replacement, but have you checked the linkage? I had a similar problem when I put my engine back together - I had the bottom of the shift arm facing too far forward. When I would shift to second gear it would engage 2nd briefly then immediately pop back into neutral as soon as I got back on the throttle (not engaging fully). I'd try shortening the throw before ripping into the engine.
Old Feb 23, 2008 | 12:59 PM
superbling's Avatar
+1 on the linkage adjustment. Try this FIRST.
I'd also say that replacing the superhawk clutch is a little more involved than many other bikes. You have to drain the coolant, which means removing the right side fairing which for me meant removing the entire front end as one piece as that was easier in the end. You also need to take great care when replacing the engine cover because if the waterpump impeller isn't properly aligned, you can snap it right off (BTDT!).
Old Feb 26, 2008 | 09:07 PM
Edwards07's Avatar
The Underdog
Edwards07 is on a distinguished road
How about the type of plates he's looking at? I've seen some EBC plates that sound pretty good as well as the Vesrah ones. Any other suggestions?
Oh, and good call on the linkage solution. I have the same problem, so i'll give 'er a try once i get the chance. Thanks!
-Miles
Old Mar 4, 2008 | 04:26 PM
XLSR-VTR1's Avatar
XLSR-VTR1 is on a distinguished road
I thought I needed to replace my clutch and did at 23k.. put Barnett springs in there too. I was fairly tough on it due to lots of track days, but when I pulled the old clutch plates they didnt look worn at all, I was shocked.
Does it slip? Springs might just be the answer. if you feel pulsing in the lever when fanning it hard its probably the basket fingers are getting little wear ridges on the fingers the clutch plate fingers fit into. It will feel lumpy, I used a very fine file and smoothed them just a little based on advise from my mechanic friend and it helped.
I did install the new clutch plates anyway and now have a replacement set for when these ones really wear out, Ive got 30k on them and last fall when I replaced the cam chains I checked the clutch and they still look new, I think they'll last a long while unless you are really beating the crap out of it.
rafbo
Jul 16, 2011 10:24 AM
cel2620xl
Apr 2, 2011 11:59 AM
dannyz
Jul 19, 2010 07:21 AM
patience
Motorcycle News
Apr 13, 2010 10:31 AM
acarp
Sep 20, 2009 11:14 PM
