i need engine help please!!
Old May 15, 2011 | 05:34 PM
  #31
RWhisen's Avatar
Former Superchicken Owner
Originally Posted by trey10130
okay so i finally took off the valve cover off alittle bit to see the cam sprocket and the chain came off and is just laying in the bottom there by the crank sprocket. so my question now is is there a link someone can give me that shows me how to retime it? and this there anything else i should look for when i do it? i plan on replace the tensioners with manual ones but i'm just wondering if i should look for anything else?
There is loads of information if you search for manual CCTs, APEs, etc etc. If you blew your OEM CCT, there is most likely damage to the valves and piston. Sounds like a rebuild.
mootsmadness
Sep 11, 2011 10:51 AM
ETHAN
May 21, 2010 11:12 AM
mcadena89
Jun 3, 2009 12:04 AM
Century 21
Apr 16, 2009 10:40 AM
mattvdsande
Mar 16, 2009 11:12 AM
