I cracked open my radiator and found metal powder???
Old Jun 26, 2011 | 08:57 PM
j shizzy wizzy's Avatar
mildly retarded
Unhappy I cracked open my radiator and found metal powder???
the one thing i have brushed off since i got my bike was the radiator fluid. Although it is very clean and everything works fine, I am replacing it due to its age.
well I opened one radiator and found what appears to be a ring of aluminum powder on the caps rubber seal....is this possibly normal if the bikes fluid has never been changed?
Not sure what to think right now. I'm going to use some prestone rad cleaner than i have been sitting on forever and then put new fluid in and keep an eye on it..
what do you all think? water pump may be going? normal break in crude/build up?
Old Jun 26, 2011 | 08:58 PM
mildly retarded
I'm going to put a couple pics up later
Old Jun 26, 2011 | 09:07 PM
Well if you had no issues with cooling I would say the impeller was installed a little off and it took some material from the housing.
Clean the system out and keep an eye on it but you should be fine.
Old Jun 26, 2011 | 10:13 PM
It sounds like the PO put Alumaseal in the cooling system to fix a small leak.
Alumaseal has been around forever, like Bar's Stopleak. The original formula is just aluminum flakes that come in a small tube, about 1" x 3".
I didn't like using it too much, better to fix the leak properly. But we always kept several tubes in the toolroom at school.
Old Jun 26, 2011 | 10:42 PM
oahu hawk's Avatar
geezer
My thoughts exactly...
Old Jun 27, 2011 | 09:08 AM
geekonamotorcycle's Avatar
Argh me too. I am afraid to look.
Old Jun 27, 2011 | 07:38 PM
mildly retarded
heres a theory, maybe they put that stop leak in there due to the weeping issue? oh well, all i can do is replace and watch.
thanks
Old Jun 27, 2011 | 07:55 PM
fred's Avatar
Mid-level Member
fred
it's one or the other. neither should cause you too much alarm. you're gonna flush the system, i believe. clean that crap off the inside of the hoses where they attach to the radiators, etc. in order to avoid leaks and you should be golden.
--fred
Old Jun 27, 2011 | 07:56 PM
kai ju's Avatar
another theory is that the water pump shaft was incorrectly installed when the clutch cover was replaced and the impeller was rubbing on the water pump housing.
This is obviously null and void if the cover has never been replaced.
ohiophotog
May 26, 2015 06:57 AM
vinkate
Nov 7, 2012 04:21 PM
johnnyhonda
Apr 2, 2007 09:15 PM
cb21983
Mar 19, 2007 02:33 PM
W-O-T
Sep 20, 2005 11:44 AM
