How to remove oil filter?
Old May 9, 2013 | 01:41 PM
Chrisguilday's Avatar
Chrisguilday is on a distinguished road
The manual says to remove oil filter with a wrench. There is no bolt on my oil filter. How do I remove it? My new filter has a bolt...
Old May 9, 2013 | 01:47 PM
1971allchaos's Avatar
I just can't.. just can't..............
Remove the lower chin fairing, then "Lefty Loose", Righty Tighty"...
Most of the time, just remove it with your hands....
Old May 9, 2013 | 01:49 PM
Wicky's Avatar
Oil Filter Wrench
Originally Posted by Wicky
So I gotta buy a cover? Does auto zone / advanced auto parts have one?
Old May 9, 2013 | 01:50 PM
I have the fairing removed. It doesn't seem to budge...
Old May 9, 2013 | 01:59 PM
KCCO's Avatar
If it won't come off by hand, the above shown tool is the best way. I'm cheap, so I just used a large pair of channel locks or a pipe wrench. Be mindful not to put up or down force on the filter, you don't want to mess up the threads. After it's off check the threads and if all looks good, put some oil on the new filters seal and put it on HAND TIGHT. Do not use the nut to tighten it.
Old May 9, 2013 | 02:00 PM
If you don't have a filter remover, you can hammer a screwdriver or similar punch into the side of it and that will give you enough leverage to unscrew it. Once you start hammering you're committed, though!
https://www.superhawkforum.com/forum...-filter-28766/
And don't screw the new one on as hard as the PO.
Old May 9, 2013 | 02:04 PM
So I don't torque the filter at all? I don't have a torque wrench.
Old May 9, 2013 | 02:12 PM
Your making this way too hard, but are asking questions before doing something dumb , so you get credit for that..
It most times will come off by hand, if not you use a tool.. buy one, make one, use a screwdriver like suggested.
It goes on hand tight, turn till the lightly oiled gasket makes contact, turn 3/4 turn.. Fill with oil, go ride.
Old May 9, 2013 | 02:17 PM
Wicky's Avatar
Impaled Oil filter
Old May 9, 2013 | 02:21 PM
Definitely not. Do not use the nut on the end to tighten it. That's just there for removing it.
Old May 9, 2013 | 02:35 PM
Caffeine's Avatar
Caffeine is on a distinguished road
best bet is to watch a vidoe! I don't agree with all of it but it's not wrong to do it this way.
Old May 9, 2013 | 05:51 PM
Make sure you coat the rubber ring on the new one with clean motor oil. Spin it on til tight, then maybe another 1/4 turn to seat it (so hand tight).
Also, on a related note, just found this good deal on oil
CASTROL - ActEvo X-Tra 4T Semi-Synthetic 4-Stroke Motor Oil - Semi-Synthetic - 4-Stroke Oil - Oils - Accessories - CycleGear - Cycle Gear
I have had to drive a screwdriver into them alot to get them free. With the oil drained, how can you get to a store to buy a filter wrench?
Old May 9, 2013 | 06:25 PM
Alright i just shoved a screw driver in it and turned it. Still was really hard... Used oil on the ring and grooves etc. Put new oil in it. Thanks guys.
*EDIT* My friend was going to get me the filter wrench.
oicdn
Jul 30, 2015 07:09 PM
thedeatons
Apr 21, 2015 04:51 PM
roisman
Apr 1, 2007 02:08 PM
timdske
Feb 22, 2007 08:53 AM
willie
May 20, 2006 08:29 PM
