How often do you have to check your manual CCTs?
Old Apr 24, 2010 | 09:12 AM
luis saleiro's Avatar
luis saleiro is on a distinguished road
This is a question for those who have swaped to manual CCTs, APEs or others.
Ok guys, i need to know if those manual CCTs have hight, low or no maintenance at all, in order to make up my mind about replacing my CCTs.
I need to know if i´m going to worried about them or if i can relax and forget about it.
Old Apr 24, 2010 | 09:16 AM
dshakes's Avatar
dshakes is on a distinguished road
As far as i know and from what i have learned on here they are very,very low maintenance. I swapped mine just for piece of mind to manuals. I definitely recommend the swap and getting manuals.
Old Apr 24, 2010 | 09:55 AM
Um... I did check them 2 years ago... I think...
Nah, seriously, I "check" them every now and then along with all the other stuff, oil-change and what not... All you need to do is listen to the bike... I have adjusted them once but that was probably unnecessary...
Old Apr 24, 2010 | 10:38 AM
How many miles or km do you start to hear that caracteristic noise of a sewing machine, telling you it´s time to adjust the manual CCT´s?
This will give me a better idea.
Old Apr 24, 2010 | 10:46 AM
Kendrick's Avatar
The Hypno-Toad
Once a year. I didn't adjust them. It sounds OK.
Old Apr 24, 2010 | 11:02 AM
I do about 7-8k km per year on my bike... And like I said, I have adjusted them once in two years... Not because it was needed, but because I was fiddling and couldn't leave well alone... No noise at all after that time/distance, so longer than that...
Old Apr 24, 2010 | 01:27 PM
comedo's Avatar
I check them when I check valve clearances. I check valve clearances every 24,000 km. or so. YMMV but probably not.
Old Apr 24, 2010 | 01:38 PM
YMMV = ?
Old Apr 24, 2010 | 01:45 PM
Your
Mileage
May
Vary
Old Apr 24, 2010 | 01:55 PM
Thanks
Old Apr 24, 2010 | 05:19 PM
comedo's Avatar
Sorry, Luis. I should have avoided using an idiomatic expression.
Old Apr 25, 2010 | 04:41 AM
Not a problem Comedo, i´m learning a lot with you all, including idiomatic expressions.
Please keep inputing about your manual CCT´s, it´s getting interesting.
Old Apr 25, 2010 | 05:13 AM
uchi's Avatar
whats the proper procedure to check them? do you have to find tdc like you do when you install them? or just loosen the nut that locks it in place and back it off a bit and tighten it again?
Old Apr 25, 2010 | 05:17 AM
Stevebis1's Avatar
I've checked mine about every other month.
Yup, they're still in the garage on the shelf.
Need to get those installed one of these days...
Old Apr 25, 2010 | 05:26 AM
I just let the bike idle, loosened the lock nut and adjusted tension until the noise was the lowest... To tight and it squeels like an angry piglet, to loose and it rattles...
Keep in mind that the bike should be fully warmed up to operating temp before you do this, it will just barely rattle on a cold start when adjusted properly and be quiet at temp... Also, small slow movements... If you start going bonkers with the wrench you will break stuff...
Old Apr 25, 2010 | 06:19 AM
Kendrick's Avatar
The Hypno-Toad
Going bonkers with a wrench has to be my new favorite expression.
Old Apr 25, 2010 | 06:28 AM
peterpanic's Avatar
pragmatic anarchist
+1 I liked the international flavor of Going bonkers with a spanner, but when I thought about it wrench seemed to fit the actual scenario much better!
Old Apr 25, 2010 | 06:48 AM
You sure you're not thinking of wench?
Old Apr 25, 2010 | 06:57 AM
You do this with the bike functioning? With the Engine running?
Old Apr 25, 2010 | 07:13 AM
Yeah... How else are you going to set it? There is no way of measuring the torque or amount of tension in any reliable way...
You pre-set it to an approximate value when you install it... Ie you set them finger tight... That means as hard as you can turn the nut with your bare hand, no tools and then back of about 1/4 turn... But that's just a pre-set, not the final value... That is adjusted with the bike running... Same as I described...
The chain slacks somewhat once warmed up, so the small rattle when cold means it's just barely tight then and correct when at temp... Always adjust at temp, not cold...
Old Apr 25, 2010 | 07:20 AM
Damm, you´re as fast as helpfull!
Thanks Tweety.
Old Apr 25, 2010 | 07:26 AM
uchi's Avatar
Ok so tighten till it breaks then back off a hair. Gotcha
Old Apr 25, 2010 | 04:25 PM
Kendrick's Avatar
The Hypno-Toad
Going bonkers with a wench...that's what I meant.
calitoz
Nov 6, 2025 10:45 AM
insulinboy
Oct 23, 2013 07:39 PM
98blackhawk
Aug 6, 2007 07:26 PM
Randman
Mar 30, 2007 05:38 AM
Randman
May 2, 2006 04:25 PM
