How hot is too hot?
Old Sep 4, 2008 | 12:19 AM
Vega (streetfighter)'s Avatar
Vega (streetfighter) is on a distinguished road
How hot is too hot?
It gets pretty damn hot in the Sacramento area. Last week it was triple digit weather. When I ride in this crazy heat the temp on my hawk is really high. I have an 02 with a digital temp gauge and during the day its not uncommon to see it 210-218. When its really hot and in traffic I have seen it as high as 225-227. How hot is too hot. When should I pull over and let it cool down. My bird does not have any fairings so the air is not directed to the side mounted radiators, but the fan does come on when it gets to the 210ish range.
Old Sep 4, 2008 | 03:06 AM
smack doogle's Avatar
smack doogle is on a distinguished road
That seems pretty normal to me and I'm up in New England. Of course, in traffic on a 90+ degree day I'll see it bounce off 225 and come back down but thats after a couple miles of stop and go. On the highway on days like that it'll sit around 190-200. As long as you don't come up on 240-250 you should be fine.
Old Sep 4, 2008 | 03:48 AM
RK1's Avatar
RK1
According to Honda, "too hot" is 250F. That's when a red light starts flashing on the temp readout and Honda says shut off the bike. I've never seen it, but have been in the low 230s a couple times. I think the temps you're reporting are normal for a hot day in traffic.
Old Sep 4, 2008 | 06:39 AM
sassage's Avatar
so where do all these temperatures reside for us analog gauge guys?
Old Sep 4, 2008 | 08:20 AM
Death Cattle's Avatar
if your bike is getting too hot, swap out your antifreeze with engine ice. i use engine ice in my dirt bikes and it makes a noticeable difference.
Old Sep 4, 2008 | 09:32 AM
rbrais's Avatar
Waaayyyyyyyyyyyyyy over to the right side.
Old Sep 4, 2008 | 09:35 AM
sassage's Avatar
a wiseguy, eh?
Old Sep 4, 2008 | 10:28 AM
RickB's Avatar
There is cooler activating fan temp switch available (on ebay iirc) that will make the fan come on sooner or you can add a switch that provides a ground to the wire at the temp switch in the rad like I did and turn it on when in stop/go traffic. Engine ice and water wetter (i'm using this) also seem to boost cooling.
has anyone ever found and tried a higher temp thermostat? thought is that at high water temps the thermostat stays fully open and the water flows so fast in the radiators and doesn't get a chance to cool off.
Old Sep 4, 2008 | 10:50 AM
This is a fallacy, as the amount of heat that water can carry is so high, that even though the water sitting in the radiator would get somewhat cooler, you are better of pushing it around the closed loop and back to the radiator as quick as you can, rather than slowing the water down and allowing pockets of steam to form in the engine block.
Besides, as that water is "cooling off" the water in the engine is getting even hotter..
Old Sep 4, 2008 | 11:02 AM
FL02SupaHawk996's Avatar
Fastest Color
Sounds normal to me...I run in some serious heat down here in FL this time of year too and I see those temps on my 2002 SH in traffic
I do run a water wetting solution that appears to help, but not that much...
If you're at a long light just shut her down till it changes
RC
Old Sep 4, 2008 | 11:16 AM
Thanks for all the quick replies. Thats just one less thing to worry about now. I bought the bike used a month ago and am putting on some serious millage. About 1800 miles in the month I have had it and the last thing I need is for some **** to break.
Old Sep 4, 2008 | 05:15 PM
filter69's Avatar
Thats Mr Dill hole to you
Well middle is normal and (drum roll plz) to hot for us is when it goes in to the (wait for it.....) the red ta da !!!!!
im sorry im not attacking u sassage i just figured i would add some humor to it
Old Sep 4, 2008 | 09:06 PM
Motohead's Avatar
Motohead
Okay, I'm OCD about this kind of stuff so keep that in mind, but when you get the coolant in that 220-230 range your oil temps are going to be in the 240-250 range: pretty hot regardless of the type of oil you're using. Ideal engine oil temp is 220 (just hot enough to burn off fuel contamination and condensation); for every 20F you see over that you cut the oil life in half whether it be mineral or synthetic.
Definitely run a surfactant like Water Wetter or Purple Ice (no first-hand experience with Engine Ice but I'm sure it works just as well, it's simple technology). If you can get a
away with it, run a higher water concentration as water is a better coolant due to having a lower surface tension than glycol meaning it absorbs and dissipates heat more effectively as well as reduces hot spots. The two surfactants mentioned do have corrosion inhibitors enabling the use of more water in the system. I run a manual fan switch I click on at the 1/4 mark and 20% anti-freeze with Purple Ice. I can't remember the last time I saw more than one or two ticks above mid-way even sitting in Houston traffic. Fan off and cruising it will stay at the 1/4 mark on my analog gauge. 20% glycol will give you a freeze point of roughly 20F (-7C) - we never see below 30F.
Old Sep 4, 2008 | 09:19 PM
superbling's Avatar
EXCELLENT question. I've notice that only the digital gauge guys post the "hand wringing" temp questions now-a-days.
The VTR doesn't typically run hot enough to overheat so don't worry.
Old Sep 4, 2008 | 11:54 PM
cal2az's Avatar
Az/Texas Rider
cal2az is on a distinguished road
Its over 100 degrees every day here and I dont get above 225 on my '04.
wsharpman
Jul 4, 2012 02:31 AM
8541Hawk
Jun 29, 2012 05:24 PM
johnnyhonda
Jul 26, 2010 01:53 AM
ClevelandSuperhawkRumble
Apr 21, 2007 06:20 AM
xecutech
Apr 10, 2007 06:45 PM
