Hot pipes...
Old Apr 29, 2010 | 05:18 AM
mattmcgyver's Avatar
mattmcgyver is on a distinguished road
Hot pipes...
So I'm curious about this.
I was checking my front air pressure the other pre-dawn morning and noticed that my front exhaust was glowing dull red.
Bike was warmed up, choke on half, idling around 1200, had been running for about 5 minutes.
Bike runs fine, choke off idle is about 9-1100...
Dull red on uncovered pipes means about 800-1000 F.
It's only down to about halfway to the turn aft from the head, maybe 10" of pipe total.
Gonna put an IR thermometer on it to confirm.
Never seen this before in other bikes, but I think chrome would prevent it (glows hotter). So I have no idea how hot the pipe should be.
Any thoughts? Non issue?
Thanks.
M
Old Apr 29, 2010 | 05:21 AM
Billzilla15's Avatar
sounds like its running lean on the front cylinder
Old Apr 29, 2010 | 05:40 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
Could also be the quality/thickness of the pipe if aftermarket. I had a Yamaha XT500 that I used to be able to light my cigs off of when out riding.
Old Apr 29, 2010 | 05:48 AM
mboe794's Avatar
I've noticed this a time or two on my SH. It happens nearly anytime I let my 450 idle for more than a few minutes (rev it and it goes away). I see it on MX bikes all the time. I think that has to do with the fact that many have titanium headers. Anyway, I've never worried about it on any bike.
Old Apr 29, 2010 | 07:21 AM
but why wouldn't the rear one be doing the same thing then if it was the headers
Old Apr 29, 2010 | 08:20 AM
Oh right, Stock everything and I didn't notice the rear pipe. It was my head against the motor that made me notice the front one.
M
Old Apr 29, 2010 | 09:17 AM
You're leaving the choke on too long. Honda says over 30 seconds of choke could cause engine damage. The rich mixture is causing elevated levels of hydrocarbons to exit in the exhaust. And especially if you have the PAIR, it then burns in the exhaust. And set your idle up to 1300 or 1400 rpm warm. That should help your warm-up with the choke off after 30 seconds. You may need to hold the throttle for a minute, but that's better than washing the oil off your cylinder walls.
On carbureted cars I've seen catalytic converters glowing cherry red when the choke was not "kicked down" after starting a cold engine. This would happen after about 5 minutes while running at fast idle.
Old Apr 29, 2010 | 11:00 AM
thusspakebenji's Avatar
thusspakebenji is on a distinguished road
^+1
I just got my Haynes manual and it said something to that effect as well. The times I've started mine up it needed about 10 seconds of choke and then ran beautifully. 5 min of choke is quite a long time...for anything.
HU112BU
May 21, 2015 05:37 PM
wsharpman
Jul 4, 2012 02:31 AM
johnnyhonda
Jul 26, 2010 01:53 AM
Vega (streetfighter)
Sep 4, 2008 11:54 PM
CNI Dawg
Nov 3, 2005 09:12 PM
