HICCUPS!
Old Oct 23, 2013 | 12:01 AM
CaryDG's Avatar
HICCUPS!
What actually causes the occasional minor backfire (Hiccup) through the carbs? It usually happens when blipping the throttle at low RPMs. Is it caused by Fuel screw adjustment, Pilot jet size, needle height, slide lift rate, or a combination of the aforementioned circuits. Too Rich or too lean? Just wondering. Any, or all, thoughts welcome.
Old Oct 23, 2013 | 12:42 AM
jerryh's Avatar
I think lean. Jumping up the pilot help?
Old Oct 23, 2013 | 01:34 AM
Not saying this is your cause, but my bike had the exact same issue as yours, and after syncing the carbs, the problem went away almost completely.
Old Oct 23, 2013 | 08:13 AM
insulinboy's Avatar
K&N filter?
Old Oct 23, 2013 | 08:22 AM
996thehawk's Avatar
996thehawk is on a distinguished road
Originally Posted by insulinboy
K&N filter?
I have a K&N and mine does it at least once every time I ride. I'm switching to OEM this winter.
Old Oct 23, 2013 | 09:10 AM
twist's Avatar
my 2002 hawk was doing that and driving me nuts! I finally got it tuned out by carefully adjusting the air screws. These carbs are finicky and very sensitive.
Old Oct 24, 2013 | 01:26 AM
CaryDG's Avatar
Helped, but...
Carbs synced, #48 pilots help but feels fat (rich) off idle, played w/ fuel screws little change. Does it more with #45 pilots then it does with #45S (Honda Proprietary). #45's feel crisper so I'll just get used to it as I'm rarely near idle!
I am one of those SH owners that like s the DJ/K&N set up. It took a while to get it where I liked it as they rely on mains and needles leaving the off idle, small throttle opening a tuning challenge. That said I ordered new OEM springs and needles to try Hawks set up. I'm getting very proficient at carb removal and installation!
Old Oct 24, 2013 | 02:19 AM
jerryh's Avatar
Hey Cary my bike rarely sneezes. Seems like when the engines cold or not quite up to temp
Old Oct 24, 2013 | 08:08 AM
OhYouJest's Avatar
OhYouJest is on a distinguished road
Ride around with the choke on, just a little. If it runs better, you're running too lean. Diagnose from there.
