Help with CCT
Old Mar 25, 2021 | 07:08 PM
Silverbenji's Avatar
Silverbenji is on a distinguished road
Help with CCT
So I replaced the CCt's. the rear had mono issues and then the fronts clicked twice and I double checked everything and fixed the issues so I hand cranked the engine a lot so I was sure I fixed the issue. I put everything back together and I turn not on. It struggled to turn over & was weak but then it did. I believe I heard some clicking so I shut the engine off. I went to turn the engine by hand but I think it has to much pressure because the was a lot of resistance and it pushed back once I released. Also with the key on the bike won't shift out of neutral. Any ideas?
Old Mar 26, 2021 | 04:14 AM
Did you use zip ties on the chains while you replaced cct's?
Basically, recheck cam timing. And one thread with this question will suffice. No need to start many.
Old Jul 1, 2021 | 07:55 AM
Relsadld's Avatar
Relsadld is on a distinguished road
so much wonderf and innovative work sir...
Tutuapp 9Apps Showbox
Old Jul 1, 2021 | 07:01 PM
Thanks?
Old Jul 2, 2021 | 04:12 PM
Just a reminder, you can have the timing marks 360 degrees off. That’s TDC compression (which is you want) and TDC exhaust (not what you want). If you took the valve cover off easy to see.
Silverbenji
May 29, 2021 04:52 PM
Cursio
Jul 19, 2011 07:00 PM
simone
Jun 5, 2011 06:13 AM
psyclown
Jan 11, 2010 01:10 PM
Century 21
Apr 16, 2009 10:40 AM
