Having trouble with front brake pad pin hanger caps...
Old Mar 25, 2015 | 02:41 PM
ohiophotog's Avatar
ohiophotog is on a distinguished road
It's been a few years since I did the pads on my '98 Hawk. Went to go change the pads today and for the love of God I can't get those pin hanger caps to budge. I tried a flathead socket with a ratchet along with PB Blaster, no luck, almost rounding off the edge of where the blade goes in. Anybody have any advice on how to get these out? Holding up my whole brake job
I've attached the parts diagram, they are #11
Attached Thumbnails Having trouble with front brake pad pin hanger caps...-brcap.jpg
Old Mar 25, 2015 | 03:17 PM
thetophatflash's Avatar
Torch. Warm it. May have Loctite or corrosion. Proper use of heat is a must.
Old Mar 25, 2015 | 03:23 PM
thedeatons's Avatar
I use a hand impact with a slotted bit inserted. Looks like a big huge screwdriver. You hit the end with a hammer and it turns the bit about 1/8th of a turn in whatever direction its set to.
James
Old Mar 25, 2015 | 03:47 PM
+1 on the hand impact driver. Those things go through a lot of heat cycles in use. Be 100% sure to use anti-seize on those and the pins on re-assembly.
A hand impact driver is cheap enough to go get one for this & always have it. ($15)
Old Mar 25, 2015 | 04:52 PM
ohiophotog's Avatar
Thanks everyone for the advice, I will try some heat and the hand impact driver. You would think Honda would have come up with a better idea for caps for these pins, but I'm not an engineer. I'll have to order some new caps once I get the old ones out unless I can find something that would work as good and easier to remove.
Old Mar 25, 2015 | 06:54 PM
Put on anti seize when reinstalling.
Old Mar 25, 2015 | 08:05 PM
Second and third the heat and a impact driver..
For install anti sieze or Teflon tape, whichever is hander.
Old Mar 25, 2015 | 09:28 PM
Wicky's Avatar
Heat
Replace them with stainless steel hex versions (10mm fine thread (M10 x 1)) with copper grease.
GRUB SCREWS STAINLESS STEEL M2 M2.5 M3 M4 M5 M6 M8 M10 HEX SOCKET CUP POINT 304 | eBay
Old Mar 26, 2015 | 09:28 AM
Originally Posted by Wicky
Heat
YES...
Except he is in the US and they are called set screws mostly here.
So M10x10 5mm long
Old Mar 26, 2015 | 09:50 AM
ohiophotog's Avatar
Heat
PERFECT!!!!! Exactly what I was looking for, I will hit up Pro-Bolt or Ebay.
Old Mar 26, 2015 | 10:16 AM
ProBolt has the RIGHT size cap in SS
Its more then you'll pay on fleybay with shipping... but its the correct size
Stainless Caliper Pin Front Grub Screw x2
Of you can have them in Titanium as well
http://www.probolt-usa.com/vaf/produ...9&p=3&x=31&y=5
Old Mar 26, 2015 | 10:22 AM
ohiophotog's Avatar
Just got off the phone with them, I can get them in TI gold color. Honestly I rather just get them from Pro-Bolt. I did a search on Ebay and all the sellers selling Grub bolts are outside the US. I was hoping Parts-Unlimited or Tucker Rocky would have them but they don't. While I'm at it gonna order 3 since the rear uses the same part number, and I will replacing the pads soon anyway.
Old Mar 26, 2015 | 04:33 PM
thedeatons's Avatar
DRAT! Another thing to buy!
What about the back brake?
How much $$??
James
Old Mar 26, 2015 | 04:50 PM
ohiophotog's Avatar
How much $$??
James
I ordered the back as well, they all came out with the manual impact driver. I work at a Honda dealer, got all 3 Titanium Gold grub screws for under $20 with shipping.
ReillyDoorn
Apr 30, 2015 01:28 AM
asdf33
Jun 11, 2014 12:23 AM
smokinjoe73
Forum Feedback
Jul 1, 2012 12:06 PM
Crashrat
Dec 13, 2009 07:17 AM
Quickling
Apr 17, 2009 06:53 AM
