Got Spark, Compression, and fuel.. No fire..
Old Jul 4, 2006 | 07:53 PM
dustinwild's Avatar
dustinwild
Okay, I have this on another post, but I really need to figure this one out. I have spark when I pull the plug and hold it against the block. It is wet when I pull it out, so I know it is getting fuel, and it has good compression when I tried to run it with only the front cylinder. But, it won't fire at all. Not even intermittently. Nothing. I tried different plugs, cause I have heard that some plugs will fire when not under compression, but none of them work, and all of them spark like heck when I hold them agains the block. I tried wiggling the plug wire to see if I would get a little bit of a fire, and nothing. I am lost. Please help.
Old Jul 5, 2006 | 10:51 AM
Speed_Demon's Avatar
What gap are you using on the new plugs?
Old Jul 8, 2006 | 05:19 AM
shayne's Avatar
I would check your coil and plug cap resistances as well, as they could be a factor. It is just going to be process of elimination I think.
hondavtr1000sp2
Nov 17, 2014 09:07 PM
jscobey
Jul 11, 2014 04:30 PM
barncat
Aug 20, 2012 07:46 AM
flyguyeddy
Apr 18, 2007 01:57 PM
faz
Apr 21, 2005 12:33 PM
