Fuel tank swap.
Old Sep 26, 2006 | 04:29 AM
MisterMohawk's Avatar
MisterMohawk
Fuel tank swap.
I searched but couldn't find anything about this: can I usa a late model tank with an early model Shawk? I can get an 02 tank but will it work on my 98? Is the tank guage just an additional connector or is it integrated into a single connector?
Old Sep 26, 2006 | 10:07 AM
marmaladedad's Avatar
Hmm?
Same tank. Hasn't ever changed here in the US.
Old Sep 26, 2006 | 10:04 PM
BeerHunter's Avatar
Slacker
If you are buying the newer tank to replace a damaged older model tank, then all you would need to do is remove the fuel sending unit from the old one and install it on the newer tank in place of the float sensor.
Old Sep 26, 2006 | 11:48 PM
MisterMohawk
Alright, thanks.
Old Sep 28, 2006 | 04:22 AM
shayne's Avatar
If you want a larger tank a European/Australian 19 litre one fits once you get the new fuel tap and hoses to go with it. No other changes.
theosagekid
May 3, 2014 06:38 AM
Jack Flash
Aug 5, 2012 06:24 AM
kostritzer
Jun 13, 2012 10:34 AM
Fox
Dec 14, 2010 11:46 AM
seb421
Feb 4, 2009 05:49 AM
