Fuel screw search
Old Feb 27, 2013 | 11:09 AM
Fuel screw search
So cycle gear and flex jet both have finger adjustable fuel screw replacements that fit an FCR carb on a dirt bike.
Has anyone found one that fits the hawk? I called those 2 and they dont think it crosses over.
Old Feb 27, 2013 | 11:25 AM
Jack Flash's Avatar
Well take off, eh.
Smokinnnn, I'm in the middle of looking for this right now. I'm not having much success, since no one really responds back to me.
Here are the specs we are looking for.
1- 15mm from base of thread, to tip of needle
2- 0.50mm thread pitch
3- M6 thread
If you work with that, maybe we can find something. I may have found something at J & P cycles that works for the Kawasaki, but still waiting for an answer.
Old Feb 27, 2013 | 12:48 PM
My mechanic buddy says none of the ones I linked to him would fit. I just realized, you cant even buy them from ronayers right? Since we are not supposed to tamper?
Its just a pain to remove the ones I have for him to braze but it may come to that depending on how bad I want this done.
Old Feb 27, 2013 | 01:07 PM
GTS's Avatar
GTS
Seasoned tech
That'd be sweet to have an actual **** on the end of the screw. I just cut a groove in it so that I can use a flat blade screw driver to adjust it.
Old Feb 27, 2013 | 01:18 PM
What is number 6: is it the fuel screw?
Ronayers.com Microfiche Honda>Motorcycle>1998>VTR1000F>CARBURETOR COMPONENT PARTS
Old Feb 27, 2013 | 01:37 PM
Jack Flash's Avatar
Well take off, eh.
Originally Posted by 7moore7
Yes it is.
Old Feb 27, 2013 | 01:53 PM
SCREW SET
Mfg. Part Number: 16028-MY5-890
$12.35 from Ronayers, and you can get um from SUDCO as well.
No aftermarket part i know of, would need to be a custom set up
Old Feb 27, 2013 | 08:29 PM
So for $25ish + shipping I guess its that vs removing them and taking em to be brazed, then re-installing.
Old Feb 28, 2013 | 04:43 AM
cybercarl's Avatar
I haven't had another reply back from them after enquiring about the length from the base of the thread. Maybe I should not have mentioned that I did not intend on using it on a Harley I did ask if it would fit Keihin series 21 carbs.
Yes that's we we have in the UK. It's not capped off like yours over there. It's just a recessed screw with the needle on one end. There's also a spring, washer and rubber O ring attached over the thread. But because it's recessed we still have access problems with getting a right angled screwdriver in there.
Old Feb 28, 2013 | 05:37 AM
Tomic's Avatar
Tomic is on a distinguished road
I am working on something right now, if it actually work I am gonna be able to adjust my carbs with two ***** fixed besides the choke ****...
Old Feb 28, 2013 | 10:51 AM
twist's Avatar
waiting with baited breath!
mikstr
Dec 8, 2012 12:24 PM
Fox
Dec 14, 2010 11:46 AM
yruyur
Feb 18, 2009 05:54 PM
cscrawford
Dec 2, 2007 03:13 PM
selztoad
Aug 26, 2006 08:05 PM
