Fuel leak
Fuel leak
So I have noticed that if I leave my bike in the sun above about 70 degrees that I get a small puddle of fuel leaking out of one of the vent hoses. When I rock the bike off the stand I get a steady stream out for about a second. I'm assuiming that there is a vent for the fuel tank to bleed off the pressure caused by the heat, maybe it's plugged?
I could see it doing it if the tank was full so your issue is kind of strange.
There is a vent line and an overflow line to the tank. If the vent was clogged the bike would cut out like it was running out of gas after you have ridden for a while, so I doubt that is the problem
So it sounds like you are getting fuel in the overflow line but not really sure how.
The overflow line could be cracked inside the tank. You could try filling the tank up all the way and then try blowing air in the tube at the bottom of the tank and see if you see bubbles comming up through the fuel. Be sure not to put any real pressure to it though. Don't want to mess anything up.
There are 3 lines I believe all together. Am I correct in assuming one is a vent line, and one is an overflow then? What's the third? I had a check valve fail in one of my jet ski's last year, and the pressure from the tank forced fuel through the carbs and filled the crankcase. I definitely don't want anything like that happening again.
