Fuel gauge mods
Old Jul 30, 2015 | 04:38 PM
  #31
NZSpokes's Avatar
You had me at fuel gauge. After that you lost me.
All I know is if its cheap enough I want one.
Old Jul 30, 2015 | 04:50 PM
  #32
SXRguyinMA's Avatar
SXRguyinMA is on a distinguished road
Should be rather inexpensive. ~$15 for the LCD, $3 for the PCB and a buck worth of resistors and capacitors and some wire and then of course an 01-up float gauge (I got mine on eBay for $20). The enclosure will be the tricky part. I need to find the best place to mount it for easy visibility and so it looks decent
Old Aug 14, 2015 | 06:42 PM
  #33
SXRguyinMA's Avatar
Ok so after a lot of back and forth and a lot of time spent trying to find somehere to put this large LCD and its accompanying case I've decided to ditch it.
What I'm going to use instead is this nice small 10-segment LED bar graph assembly:10 Segment LED Bargraph Array Fixed Tri Color New | eBay
It will do just as good of a job but be much smaller. This means smaller PCB(s) which more than likely means going to all SMT components.
Old Sep 23, 2015 | 01:32 PM
  #34
SXRguyinMA's Avatar
Ok so I finally had more time to get this working good with the new LED display. I added in some delays and averaging to get the graph to move fluidly and not bounce all ove rthe place in direct relation to the float's movements. Here's the current code:
Code:
 *LED Fuel Gauge for Honda SuperHawk 16L Tank
 *https://www.superhawkforum.com
 *Code by Will Lyon 9/23/2015. Contact: will.lyon12584@gmail.com
 *5V to fuel sensor Grn/Blk
 *Fuel sensor Gry/Blk to Analog 0 with 10k resistor to GND
 *220 ohm resistor to each led and GND
const int sensorPin = A0;       // the pin that the potentiometer is attached to
const int ledCount = 10;        // the number of LEDs in the bar graph
const int numReadings = 30;     // use this value to determine the size of the readings array
int ledPins[] = {
  2, 3, 4, 5, 6, 7,8,9,10,11 }; // an array of pin numbers to which LEDs are attached
int readings[numReadings];      // the readings from teh fuel level gauge
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
void setup() {
  for (int thisLed = 0; thisLed < ledCount; thisLed++) {  // loop over the pin array and set them all to output:
    pinMode(ledPins[thisLed], OUTPUT);
  Serial.begin(9600);
  for (int thisReading = 0; thisReading < numReadings; // initialize all readings to zero
thisReading++) {
  readings[thisReading] = 0;
void loop() {
  total = total - readings[readIndex];        // subtract the last reading
  readings[readIndex] = analogRead(sensorPin);// read from the sensor
  total = total + readings[readIndex];        // add the reading to the total
  readIndex = readIndex + 1;                  // advance to the next position in the array
  if (readIndex >= numReadings) {             // if we're at the end of the array
    readIndex = 0;                            // wrap around to the beginning
  average = total / numReadings;              // calculate the average
  Serial.println(average);                    // send it to the pc as ASCII digits
  delay(1000);                                // delay in between readings for stability
//  int level = analogRead(sensorPin);  // read the potentiometer:
  average = map(average, 580, 913, 0, ledCount); // map the result to a range from 0 to the number of LEDs:
  // loop over the LED array:
    // if the array element's index is less than ledLevel,
    // turn the pin for this element on:
    if (thisLed == average-1) {
      digitalWrite(ledPins[thisLed], HIGH);
    // turn off all pins higher than the ledLevel:
    else {
      digitalWrite(ledPins[thisLed], LOW);
  delay(100);
Once the video is done uploading I'll post it
Old Sep 24, 2015 | 06:21 AM
  #35
SXRguyinMA's Avatar
Here's the video: https://goo.gl/photos/WMbeiffdJmd5DYsT8
The final code posted above runs the graph slower than in the video just so it's not bouncing all over the place as much. The only downside is that it takes a few seconds (5-10) for it to build up enough readings to get the gauge working. That's something I want to work on. I want to figure out how to code it so that when it first powers on it takes a reading and uses that as the display level for 10 or so seconds. Then switch to using the average part of the code. I'll figure it out
Old Oct 3, 2015 | 09:30 AM
  #36
SXRguyinMA's Avatar
Ok final code (as of right now lol). Changes: added more readings and longer delay between readings to further slow the movement of the gauge. Added sweeap sequence for the LED's at startup (purely cosmetic). I also had help getting it to read the real float value at startup so that it doesn't start from empty and work its way up.
Code:
*Code by Will Lyon 10/3/2015. Contact: will.lyon12584@gmail.com
*Help from user Doug Jefferies on the Element 14 Forums
const int numReadings = 35;     // use this value to determine the size of the readings array
int ledPins[] = {
int readings[numReadings];      // the readings from the fuel level gauge
int averagingCount = 0;         // checks the number of values in the Index
int timer = 75;                 // timer for inital LED sweep
int pinCount = 10;              // number of LED pins
void setup() {
  thisReading++) {
  for (int thisPin = 0; thisPin < pinCount; thisPin++) {      // loop from the lowest pin to the highest
    digitalWrite(ledPins[thisPin], HIGH);                     // turn the pin on
    delay(timer);                                             // delay for time set bove
    digitalWrite(ledPins[thisPin], LOW);                      // turn the pin off
  for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) { // loop from the highest pin to the lowest
    delay(timer);                                             // delay for time set above
void loop() {
  readings[readIndex] = analogRead(sensorPin);    // read from the sensor
  averagingCount = averagingCount + 1;            // increments the count for averaging
  if (averagingCount >= numReadings) {            // caps the averaging count to the array
    averagingCount = numReadings;
  average = total / averagingCount;               // calculate the average
  delay(3000);                                    // delay in between readings so the gauge doesn't fluctuate too fast
  average = map(average, 580, 925, 0, ledCount);  // map the result to a range from 0 to the number of LEDs:
  for (int thisLed = 0; thisLed < ledCount; thisLed++) {  // loop over the LED array
    if (thisLed == average-1) {                   // if the array element's index is less than ledLevel
      digitalWrite(ledPins[thisLed], HIGH);       // turn the pin for this element on:
    else {
      digitalWrite(ledPins[thisLed], LOW);        // turn off all pins higher than the ledLevel:
  delay(100);
Old Oct 3, 2015 | 11:01 AM
  #37
Wow! Good work man. Many of us appreciate what you have done here
Old Oct 3, 2015 | 11:23 AM
  #38
SXRguyinMA's Avatar
Thanks! I'll try to get a video of the current setup tonight. I'm thinking of integrating the factory low fuel LED in as well and have it also turn on when the last two red LED's are lit on the gauge. I know it's on its own PCB in the cluster and probably relies on 12V but I also know that if you jump the two pins on the gauge side of the level sensor connector the light comes on.
I may be able to exploit that or maybe just use a single LED wired to the board, seeing how it's only a few screws to remove the factory low fuel LED.
All that's left really is to design a PCB and 3D print the enclosure for it.
Old Oct 3, 2015 | 01:51 PM
  #39
SXRguyinMA's Avatar
Ok so I added a function to turn on an LED (in this case the OEM low fuel LED) when either of the last two bars are lit. I plan on using the OEM LED but removing the PCB that controls it and wiring it directly to my PCB for the gauge.
Here's the final code: ::EDIT:: apparently there's a character limit on these posts - I can't post the entire code as it cuts it off.
And here's a video of it in action. Once it's on the bike it will use the factory yellow LED, not this green one I popped in the breadboard.
Patton303
Mar 14, 2020 05:20 PM
05Titan
May 15, 2011 07:24 PM
Mike996
Nov 18, 2009 03:04 PM
tudor
Jun 24, 2008 06:56 AM
BIG DAVE 03
May 17, 2007 03:41 AM
