Front Cylinder making noise!
Old Jun 8, 2012 | 02:07 PM
jdobeckj's Avatar
jdobeckj is on a distinguished road
So I have noticed some noise from the front cylinder area, when I fire her up for the first few minutes there is a clack clack clack noise around 1000-1500 rpm’s. After she warms up the noise subsides. I change the oil religiously at 3500 miles and am on the second oil change cycle using Shell Rotella synthetic ….. Any thoughts…
Old Jun 8, 2012 | 02:12 PM
Hard to tell by just a description but it could be somethings as simple as the carb slides bouncing around.
Take a stethoscope or the screwdriver to the ear trick and see if you can pin point where it is coming from.
Old Jun 8, 2012 | 02:49 PM
saige's Avatar
the boss
Do you have manual cct's,if so,might need to be adjusted a little bit.
Old Jun 8, 2012 | 03:04 PM
jdobeckj's Avatar
aaahh, fantastic, as for the CCT's.. they are auto that came with the bike. she has 33500K on her. not too many issues over the past few years, I recently moved to Arizona from Seattle and went to a "better" oil.. I talked to a clown at the steelership in regards to the noise, he was yapping about shimming and the commitment of $650 for the job.. I also herd that the oil needs to "warm" up and get into the engine.. sooo?? I donno
Old Jun 8, 2012 | 03:08 PM
jdobeckj's Avatar
I just checked the bottle of Shell Rotella T6 its 15-40 Synthetic- maybe thinkin that might be too heavy for the bike at the cold start.. higher viscosity at colder temp's stress out the top end of the bike.... ugh?
Old Jun 8, 2012 | 03:36 PM
It shouldn't be that big of an issue, I have run it before and didn't have any problems.
Old Jun 8, 2012 | 04:02 PM
RWhisen's Avatar
Former Superchicken Owner
Better check that front CCT before "clack clack" become slap slap.
Old Jun 8, 2012 | 04:13 PM
Very true as you have passed the "recommended" change interval of 32K miles...
Old Jun 8, 2012 | 04:42 PM
GTS's Avatar
GTS
Seasoned tech
Sounds like a loose cam chain from what you describe but it's hard to say. If you were still in Seattle I'd say we should get together and I'd throw an ear on it. If you're to that mileage I'd recomend changing that CCT anyway, don't want it to come apart on you and have to pull the head and replace valves/guides.
Old Jun 8, 2012 | 05:55 PM
jdobeckj's Avatar
COOL... yeah, this has $$$ written all over it..... Thanks guys..
Old Jun 8, 2012 | 06:02 PM
jdobeckj's Avatar
Once I have this thing open and exposed replacing the CCT'S what else should I be looking for "or" what else should be replaced at that point??? any suggestions
Old Jun 8, 2012 | 06:15 PM
Check the valve clearance while you are in there.
As for $$ this should be considered "normal" maintenance and is a lot cheaper to do now than later.
outrigger
Aug 15, 2014 02:39 PM
clac
Aug 24, 2011 09:49 PM
merlyn
May 17, 2010 11:26 AM
hazzy
Aug 26, 2007 07:50 PM
CNI Dawg
Dec 16, 2005 09:09 PM
