Front Brake Pistons....
Old Jun 23, 2009 | 03:18 PM
revhighjak's Avatar
revhighjak is on a distinguished road
I just made the swap to F4I front brakes. (mc and calipers) The calipers were pretty nasty when I got them and I decided to disassemble, clean the calipers and I replaced the rubber seals for each piston.
Everything went back together pretty smoothly but now I have an issue.
Im trying to bleed them and on the inside pistons on both calipers are still all the way down and not moving. (and the handle is still mush) I assume its air behind those pistons since Im havingthe same issue on both calipers.
Any suggestions on how I could get that air out? Ive gone through a ton of brake fluid and have used a piston bleeding pump kit and pumping the lever.
Thanks in advance!
Old Jun 23, 2009 | 04:58 PM
I'd suggest starting with bleeding the master cylinder... Put a rag around it so you wont spill all over the bike and open up the banjo bolt on the master cylinder... It's a highspot and you usually get a decent sized bubble in there... That big bubble turns it all mushy and once it's gone, bleeding the rest of the system is a lot easier...
Old Jun 23, 2009 | 06:15 PM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Perhaps take the calipers off and hold them with the back of the pistons facing up
Old Jun 23, 2009 | 06:52 PM
killer5280's Avatar
Force the outside pistons back in some and the inside pistons will move out, then bleed again.
Old Jun 23, 2009 | 06:57 PM
steve.g's Avatar
I agree with Tweety, bleed the master cylinder at the banjo bolt,then each caliper starting with the one furthest from the master cylinder.
Stupid question, do you have the calipers mounted with the bleed screw at the top? If they have the bleed screw on the bottom side there will be a pocket of air that will be impossible to bleed out.
Old Jun 24, 2009 | 06:21 AM
revhighjak's Avatar
THanks for the replies. Ill try these tonight and see how it goes.
Last night I did try to push the outside pistons in and the insides still didnt move. Must be a large air pocket in there.
The bleeders are on top.
Old Jun 24, 2009 | 06:34 AM
chickenstrip's Avatar
chickenstrip
By 'bleeding the master cylinder' do you mean loosen the banjo bolt and allow some fluid to seep out into a rag? Do you guys have a speed bleeder up there? (My brakes have been 'spongy' for a long time - this might be the culprit.)
Old Jun 24, 2009 | 06:39 AM
trinc's Avatar
yes. same principle, don't let the lever bottom out to the bar.
tim
selztoad
Oct 13, 2006 04:48 AM
Motohead
Aug 20, 2006 01:06 PM
Randman
Jul 15, 2006 10:35 PM
Gerrit
May 25, 2006 10:43 PM
VTRBeefa
Jul 20, 2005 07:23 PM
