Flat spot, low power
Old Jul 11, 2013 | 12:52 PM
eersfanpilot's Avatar
New Hawk Rider
eersfanpilot is on a distinguished road
Good day everyone. Wanted to get some advice here. Put in #48s and rechecked all my carb shims and adjustments according to the carb set up thread here. Now when I try and accelerate I get no real power, instead it's just a smooth, dull, flat rev with no *** behind it. I've searched and searched for a vac leak since I get a pretty good pop on decel even though I have PAIR removed, EVAP removed and block off plates installed.
Thoughts?
Old Jul 15, 2013 | 07:01 PM
Mine did the same thing after a jet kit was installed and I think all that was changed was the clip setting. I think he had it set at two moved it to three - made all the difference. Others will be along to help my memory.
Old Jul 16, 2013 | 09:34 AM
Jack Flash's Avatar
Well take off, eh.
Did the problem exist before you put the 48's in, in thinking this would solve the problem ? Or, you did the whole carb set up with new 48's, and now it
does this ? From a quick vue, you may now be too rich.
Other questions to ask. Is it throughout the whole RPM range, or just
a certain spot in the range ? Have you tried pulling the choke to see what
happens ?
Tokke
Apr 12, 2011 04:10 AM
john
Jan 6, 2011 09:46 PM
karlpix
Jan 2, 2011 05:02 PM
shmoab
Mar 23, 2009 02:47 PM
Sablotny
Oct 19, 2008 03:34 PM
