Fitting riveted chains
Old Nov 24, 2006 | 01:08 AM
shayne's Avatar
I have just aquired a new drive chain without a master link clip for the first time in 25 years of riding bikes! This one from Sum of All Parts needs to be riveted. I do not have a riveting tool in my workshop, although I have most other things.
Has anyone used another method to fit them, or is buying the proper tool a must? It must be done securely of course, so I am not going to do anything bodgy.
A tool here costs about $90, and I will rarely use it, so I am trying to save a few bucks if one of you guys has a trick to pass on.
Cheers,
Shayne
Old Nov 24, 2006 | 01:58 AM
marmaladedad's Avatar
Hmm?
I always use a Pro-Motion chain tool. I wouldn't take the chance with my chain.
Old Nov 24, 2006 | 02:31 AM
twitcher's Avatar
twitcher
Hi Shayne, I just fitted one to my bike a month ago with a center punch, hammer and a lump hammer. I got my mate to hold the lump hammer on the back of the chain while I peened the front of the rivets. It took about five minutes and I'm totally confident with it,and have about 2000 km on it with no issues. I say do it yourself and save the money for tires.
Old Nov 24, 2006 | 05:01 AM
99Hawk's Avatar
99Hawk
My favorite tool, does a great job - yep - it costs a few bux but it will last forever.
http://www.motionpro.com/motorcycle/...riveting_tool/
Old Nov 24, 2006 | 07:46 AM
superbling's Avatar
Three choices:
1) Get a chain tool (or borrow one)
2) Use the ball peen hammer method (as described above)
3) Take to a dealership (preferrably an independent)
I do #1. I borrow one, along with his carb sync tool, from a local rider and in exchange break tire beads for him.
Old Nov 24, 2006 | 07:58 PM
Do you have a bike shop near you? Like within 10 miles? I have pressed the plate onto the link and dabbed some RTV or epoxy on there just to get me to the dealer. $5 later or a box of donuts (Saturday mornings they really appreciate these) and my chain is peened properly.
Old Nov 24, 2006 | 10:06 PM
shayne's Avatar
Thanks guys.
How do the tools work?
Are they essentially a tapered shaft on a thread that you wind in to spread the link pins?
Old Nov 24, 2006 | 10:19 PM
L8RGYZ's Avatar
Dremel tool or similar works great for cutting the ends of the peened rivets off your old chain.
Old Nov 24, 2006 | 11:15 PM
Hmm?
Originally Posted by shayne
Thanks guys.
Yep. When installing the rivet, the ends are squished flat (technical term) against the face of the chain.
Old Nov 25, 2006 | 07:25 PM
shayne's Avatar
Thanks, reckon I will make something to do the job.
Old Nov 25, 2006 | 07:31 PM
It better be tough! Those pins are hard and I've seen the cheap Motion Pro tools bend like butter when you put some torque on them. The more expensive $100 tool is better. Remember, the pin that peens the "rivet" over needs to be hardened tool steel.
Old Nov 25, 2006 | 08:07 PM
Hmm?
I'm not sure which Motion Pro tool you guys have, but mine was $100 and Motion Pro.
Old Nov 25, 2006 | 08:49 PM
Motion Pro makes two. One's heavy duty, the other not. HD is $100, the other like $40, IIRC.
Old Nov 25, 2006 | 09:41 PM
Hmm?
Ahhh, I see. Thanks for clearing that up for me.
Old Nov 25, 2006 | 10:47 PM
RonVTR's Avatar
RonVTR
You don't need to cut the chain off... No frame on the VTR... It will just lift off.
As for the tool... I rented the tool fron the local Honda mechanic for $15. It took me an hour including travel time.
Old Dec 1, 2006 | 11:51 PM
shayne's Avatar
My workshop is pretty good. I have a good selection of punches and stuff.
cameron
Feb 19, 2009 02:28 PM
roadapple
Sep 26, 2008 06:27 AM
Otto Man
Jan 17, 2007 06:47 PM
blackvtr
Sep 29, 2006 04:25 PM
grampi
May 28, 2006 09:15 AM
