Faulty RR even though new?
Old Dec 2, 2008 | 11:01 AM
PUSHrod's Avatar
I replaced a blown out and failed stock unit with a new finned Honda RR, at idle the VOM shows 13.5v DC, but as the RPMs climb, the voltage drops to 12.58 +- regardless of the engine speed. It never gets past 13vDC except at idle.
Any thoughts out there?
Old Dec 3, 2008 | 07:28 AM
RickB's Avatar
You may want to test out the stator next - its basically the alternator like you have in a car. it should have a testing procedure in the manual or try a search on here for more info.
Old Dec 3, 2008 | 11:49 AM
PUSHrod's Avatar
All three sides of the stator got to 50vDC or slightly more when tested.
Old Dec 3, 2008 | 12:39 PM
And that is decidedly low... I think my new one was at 60 ish when i scrapped the old one and replaced it...
Old Dec 7, 2008 | 12:12 PM
PUSHrod's Avatar
Well, the shop manual led me through the test for the charging system and 50vDC for all three sides was normal, ergo the stator is okay. But.
None of the tests for the RR would yield the result, good or bad, that the book said I should observe. The unit is a new finned piece from a known source. The 13.5 at idle and dropping to 12.58 as the rpm's climbed had me scratching my head.
Once more into the diagnostic chart, I figured, and got out the tools. As I unplugged the harness from the RR unit again, I noticed that the insulation on the red/white wire was slightly discolored. What the...
After I pulled the female connector from the plug and peeled the insulation back I found gray/green corrosion on the copper strands and in the wire to connector contact point. In an ah-ha moment I dismounted the wire and cleaned it to shiny bright as I did the female connector, then I soldered the two back together, applied dielectric grease, shrink wrapped the unit and reinstalled it into the plug, plugged it into the RR and ran the test again.
13.5vDC at idle and 14 as the rpm's come up to 5K. The sun is shining on me today! The bike is charging it's battery again and one more gremlin is cast out in the cold.
Old Dec 7, 2008 | 02:16 PM
RickB's Avatar
Glad to hear you figured it out...
Old Dec 15, 2008 | 05:19 PM
Tightwad's Avatar
Tightwad is on a distinguished road
Bad connections are to blame for many an R/R problem, as is poor cooling..which is often a result of a bad ground connection.
I came over from the VFRD forum at the recommendation of a member here, to offer what I could about the R/R issues we have fought there, and see what else I could learn
Tightwad
Old Dec 15, 2008 | 06:52 PM
I see you are in Texas and I also own a VFR. My R/R has been replaced by the PO on the Superhawk but the Interceptor seems to have been fitted with the finned unit from the manufacturer.
It's not surprising when you stand the two bikes up side by side. Many of the electronics on the '97 VFR were superior to the Superhawk instruments for years to come.
For me they are two different tools. When I'm on the Superhawk I don't give a **** what time it is so not having a clock is not important.
The Interceptor is the jet out of the city when traffic is light to a place a little quieter than here. If I need to get my head into the country for a breakfast away from the city. . . you won't see me leave. Like the cops, you will only hear it.
Old Dec 16, 2008 | 06:19 AM
Tightwad's Avatar
Yup, Dallas area. Some of the 90-97 VFRs also had non-finned units...probably the same one? Uses a 5 pin plug that goes directly into the R/R? Heat is the killer for this unit, grounding them helps immensely.
Old Dec 16, 2008 | 06:43 AM
Erik S.'s Avatar
Ok, speaking of VFRs, my dad has one and turned me on to a site that the VFR guys know about. www.wiremybike.com He does what he calls the VFRness, which is a new harness and R/R.
I wrote and asked him about doing one for the VTR. This was his reply:
Erik,
I am always willing to work with other bike owners to help them. The 94 VFRness was developed in just that way, and I made a one-off for a CBR owner as well. If you are able to provide measurements and photo's I should be able to help you out.
I will check out the Superhawk Forum as well.
Joshua
So who has their bike apart and can take some pictures to provide him?
Old Dec 17, 2008 | 03:38 PM
Tightwad's Avatar
[/size]
That would be me....more than happy to help if I can, the VFR versions are about a perfected as I can get, and now I need another challenge.
Lukasz Kowalczyk
Mar 29, 2013 12:31 PM
8541Hawk
Jun 12, 2012 09:35 AM
Montana
Aug 7, 2010 07:12 PM
j shizzy wizzy
Feb 5, 2009 09:32 AM
Anto
Jul 29, 2008 08:39 PM
