Engine quiets when warm
Old Sep 24, 2012 | 07:07 PM
Renderw's Avatar
Renderw is on a distinguished road
type o meant engin QUITS when warm!
not sure what's going on now.. timing was out, it's fixed.. it was smoking.. it's fixed.. started it up.. running beautifully then right about 70° it stalled.. started ruff.. back fired and quite.. tried to rev it.. it reluctantly revved and quite again.. Netural light won't stay lit, clutch does nothing.. this bike it new to me.. so I don't know what is "Normal"
any one know of anything that may cause trouble when a motor warms.. electrical?
Old Sep 24, 2012 | 10:01 PM
saige's Avatar
the boss
i know when warming up the bike,if you have the choke open,it will eventually want to die.
besides that,im not sure.
Old Sep 25, 2012 | 06:57 AM
Renderw's Avatar
no chock was turned off long before that.. I had to play with the chock to get it to fire again.. One buddies suggestion was I have a cracked head leaking antifreeze (water in my case) into the cyclinder.. I don't know...
Old Sep 25, 2012 | 08:09 AM
Explain further "clutch does nothing" Clutch isn't working?
How does your R/R look? Neutral light going out seems to indicate electrical...
Could be that the choke is broken open...
Old Sep 25, 2012 | 12:33 PM
Renderw's Avatar
my bad.. it's been so frustrating I'm forgetting little things.. the starter would not work with the clutch in.. but the stand was down! doh!! so that should solve that.. the nutral light / switch is having issues.. if I can get some contact cleaner I will try that first.. I'm not putting more money into this project until I'm 100% sure I will have a bike to ride in the end..
Old Sep 25, 2012 | 01:59 PM
Gaggenau's Avatar
Gaggenau is on a distinguished road
Have you got Manual CCT's?
I had problems with engine stopping after I installed the manual CCT's as they were set to tight, so at idle it would cut out and the starter would labour as if the battery was flat, I would have to wait till the engine was cool to start it again.
Old Sep 25, 2012 | 05:57 PM
Renderw's Avatar
FOUND IT!!
the issue was a neutral switch, when it gets hot it stops working.. no issues if your riding as the stand is up.. but with the stand down and the bike thinks it`s not in neutral - spark turns off! of course intermittent means spark is off/on/off/on/off/off/on! and BANG BANG, BANG.. As it backfires and quits and the plug comes out wet with gas! Grounded the wire neutral switch wire to the frame and engin ran perfectly.
turbotim
Jun 25, 2011 08:29 PM
babyhawk
Feb 12, 2011 09:40 AM
zwoehr
Jul 25, 2010 08:53 PM
Mike996
Dec 22, 2009 08:29 PM
Stratman
Jul 1, 2006 02:24 AM
