Engine Problems - Will not Rev past 3000rpm
Old May 19, 2012 | 07:49 PM
bensonju's Avatar
bensonju is on a distinguished road
hey guys,
I was riding when I suddenly lost engine power and couldnt get it to rev past 3000rpm. However, the engine starts and idles fine and sounds good at idle. I recently put in APE CCTs so i took the bike apart to see if the timing chain skipped or if it was loose but the timing was still correct and chain tension was fine. I then thought it might be a bad TPS sensor but from what little I've been able to find the bike should still be able to ride with a bad TPS, just a little sluggish. I checked the connector going to the tps and get 5v through the multimeter but had had difficulty getting it to read an ohm reading. Is the TPS sensor the issue? I dont want to throw a $100 sensor at it if its not the problem.
-thanks
Old May 19, 2012 | 08:02 PM
mboe794's Avatar
PVLIR!
If that means nothing to you, search that term here on the forum.
Oh, and welcome.
Old May 19, 2012 | 08:03 PM
mboe794's Avatar
Dangit, beat me.
Old May 19, 2012 | 09:44 PM
Yeah, that sensor is very low on the list of things it would be. Vacuum lock possibly. Has the bike been sitting or in the rain or did you fill it really full recently? This would cause a vacuum in the tank and not allow enough fuel to reach the carbs. Quick check for this is to try running it with the gas cap open.
Maybe one of your coils isn't working properly or connected fully.
Old May 19, 2012 | 11:36 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
My rear coil wire came loose and did this once...
Old May 20, 2012 | 12:00 AM
loserbaby's Avatar
jet wrench
loserbaby is on a distinguished road
Absolutely, I fought a problem like this for quite some time, and after much wasted time and money... It was a weak coil... consistent but WEAK. The color of the spark is what finally tipped me off and it was subtle, but occasionally yellow instead of blue all the time...
Coil,Coil,Coil!
Old May 20, 2012 | 12:28 AM
saige's Avatar
the boss
I have been having odd problems with bike,my ideas lead me to this,I have new ones coming thank god.
Only other thing it could be for me is valve adjustments or bad/dirty valves.but this is just my issue.
I would really check those coils too.
Old May 20, 2012 | 05:52 AM
maniac2313's Avatar
Good time to upgrade to sticks!
Old May 20, 2012 | 06:07 AM
BeerHunter's Avatar
Slacker
Forget about the TPS for now. You could unplug it and the engine will still run quite well.
I would suspect a problem with the carb slides not opening, such as a torn slide diaphragm.
Old May 21, 2012 | 04:34 AM
bensonju's Avatar
it turns out it was PVLIR after all - the hose didn't have a connector on it so it must have come loose while i was on the road. thanks for all the help guys, now i can get back to riding again!
Old May 21, 2012 | 05:55 AM
No no, that's too easy. Take off the valve covers and rip out your coils and may as well pull the headers off too just to be sure there's nothing in the way of the exhaust
Old May 22, 2012 | 03:42 PM
divingindaytona's Avatar
Remember stock is BAD!
Check the routing of the hoses that go to the tank, one time I switched 2 of them and had a similar problem
sdhawkrider
Sep 24, 2012 04:04 PM
midijunky
Aug 5, 2007 09:59 AM
caker
Jun 22, 2005 02:50 PM
barrysuperhawk
May 20, 2005 10:11 AM
faz
Aug 10, 2004 10:42 PM
