Engine Noise, NOT CCT, slides??
Old Apr 14, 2008 | 11:16 PM
Shortlived99's Avatar
Shortlived99 is on a distinguished road
Got a 98' with 25K miles about a week ago. At idle there is a loud ticking comin from the top of the head, at about 4K revs it goes away. Gets slightly quieter when its warmed up.
Really doubt its ccts, I was thinkin either valves or carbs?
I dont know anything about twins, this is my first. My old cbr just had loud valves. My pops thinks is just rocker arms?? Do hawks have rocker arms?? Or am I just being paranoid?
ONE MORE THING. DONT REPLACE YOUR CCTS UNLESS U DO IT RIGHT.
Old Apr 15, 2008 | 04:39 AM
smack doogle's Avatar
smack doogle is on a distinguished road
Yeah, I wondered about this when I got my SH. Doesn't really sound like a cam chain slapping against metal, kind of like a fast "poof" sound under the tank? I just figured it's the carbs since it is most proficient around 2-3k rpm. I've searched and I think it's just one of the bikes quirks.
Old Apr 15, 2008 | 07:37 AM
speedhawk's Avatar
One Wheel Wonder
speedhawk is on a distinguished road
i would put money down that it is your valves!! that matches perfect to others discriptions of valve clearance being off. i have never experienced it because i have kept my valves adjusted.
so what do you mean dont install your new CCT unless you do it right? explain! im about to put one in on mine before a long trip. i have 22,000 miles on my 98
Old Apr 15, 2008 | 05:53 PM
Speedhawk, check the Knowledge Base. There is a lengthy article on it and many, many, many threads on the subject.
Old Apr 15, 2008 | 06:13 PM
Thumper's Avatar
Still could be valves, loose valve can tighten up as the engine gets warmer and metal expands.
Doubt is a dangerous thing if she goes poof cause you ignored it.
Twins are the same as most other late model in-line fours as far as how CCT and valves work and adjust. Just double the cames and CCT's of a 4 banger.
VTR doesn't have Rockers, reference the on-line parts fiche below. The cams (#3,4,5, or 6) sit on top of a bucket/shim type of arrangement and the cam lobe pushes directly down on the bucket (#9) that sets ontop of the shim (#16) that sits on top of the valve (#7 or 8). You adjust by changing shim thickness.
http://www.bikebandit.com/houseofmot...c/m2912sch1148
Old Apr 15, 2008 | 06:18 PM
synaptik's Avatar
synaptik is on a distinguished road
speaking of valves .... lol i need to go check mine to make sure they are within spec .... another first for me :-)
Old Apr 17, 2008 | 11:47 PM
I took it to honda and they told me i was being paranoid. They said that the Hawks should make noise. Something about the valves being real tight from the factory especially the exhaust valves. Anyways, its good if u hear them. If u dont is when u should worry.
Old Apr 18, 2008 | 04:45 AM
drew_c14's Avatar
No rocker arms. Overhead cams.
Old Apr 18, 2008 | 06:41 AM
Thumper's Avatar
I don't know about that. I have nearly 30 K on mine and each time i checked them they have been in spec..
First check was at 800 miles , last check was a couple of months ago
Old Apr 18, 2008 | 06:43 AM
Thumper's Avatar
Thanks for the pic drew, Ahhhhhh nice start of the day. Gears and oil.
Hummm hummm
Old Apr 20, 2008 | 07:43 PM
Well, I just rode the bike about 600 miles this weekend and it sounds great. Just new bike noises. The tickin' im hear is obviously a good thing.
Old Apr 21, 2008 | 04:49 AM
gboezio's Avatar
Yeah, don't freak out, but still check the clearances, the front is a bit of a PITA, but it's doable.
I did mine this spring, might wanna check it out
https://www.superhawkforum.com/forum...ad.php?t=14049
Old Apr 21, 2008 | 06:02 PM
Wow, nice tune up. I wanna do something like that this winter. Not sure if i will tackle the cams. Thats a bit over my head. I was thinkin about messin with the carbs and forks. I think that will keep me plenty busy.
Thanks for the info.
Old Apr 22, 2008 | 07:13 AM
rbrais's Avatar
I had my valves checked at like 14k and one was a little off.
rr-rider
Sep 22, 2012 11:04 AM
Chester3000
Aug 15, 2009 01:26 AM
Little_Horse
Oct 11, 2008 12:21 PM
REDVTR1000
Apr 25, 2008 12:14 PM
bluesman
Aug 30, 2007 03:32 AM
