Engine Breaking SuperHawk vs Ducati SS
Old Jun 8, 2007 | 11:50 AM
Chuey's Avatar
Chuey is on a distinguished road
Just had a flash back to the Ducati 750SS that was in the stable a few years ago. I recall the bike had close to zero engine breaking. The SuperHawk has a lot of engine breaking, is there a difference in flywheel inertia? What gives?
Old Jun 8, 2007 | 03:14 PM
Thumper's Avatar
Always wondered that myself, the SV650 (i know smaller engine) has nearly no engine brake either.
It is nearly impossible to coast on a SuperHawk without instant engine brake and deceleration of coasting speed in a quick manner.
Old Jun 8, 2007 | 03:46 PM
Babelfish's Avatar
Babelfish is on a distinguished road
I've tried a 916 and as far as I can remember it was similar. Looking at the TL/SV1000 the seem to behave the same way.
SS750 may have lower compression. Air cooled, low power engine, SV650 is a much smaller engine.
Hard Engine braking is something you get when you buy a large twin.
Old Jun 8, 2007 | 04:03 PM
The superhawk has very little engine breaking if you replace the CCT's, that really is the main cause of dead engines..
But it will still have lots of engine braking, as will any high compression large displacement engine.
Old Jun 8, 2007 | 07:34 PM
Thumper's Avatar
[QUOTE=lazn;56226]The superhawk has very little engine breaking if you replace the CCT's, that really is the main cause of dead engines..
QUOTE]
Humm i had Honda replace the original CCT under warranty and then i recently replaced my Honda CCT with the APE CCT's and i noticed no difference in engine brake.
I don't see how the CCT would have anything at all to do with engine brake, its all piston compression and clutch as far as i can tell.
Old Jun 8, 2007 | 08:15 PM
Originally Posted by Thumper
Humm i had Honda replace the original CCT under warranty and then i recently replaced my Honda CCT with the APE CCT's and i noticed no difference in engine break.
I don't see how the CCT would have anything at all to do with engine break, its all piston compression and clutch as far as i can tell.
Break means to fail or get damaged.. Brake means to slow down. Thus engine breaking = buy new engine and engine brake = slow down with less throttle.
Old Jun 8, 2007 | 08:25 PM
lol he has a point...but I think the thread was about engine BRAKING not breaking/broken engines, he just spelled it wrong...there was actually a pretty interesting article in I believe cycle world regarding engine BRAKING I'd have to look around to dig it up. It didn't talk about the superhawk but I think it did compare a TL and a bunch of other engines.
Old Jun 9, 2007 | 05:25 AM
Lefin102's Avatar
I just bought a Ducati ST3 and it doesn't have anything like the SH in engine braking. I thought there was somthing wroung with it. I like the SH much better for this characteristic! However the Duck is a better sport tourer for longer distance.
Old Jun 9, 2007 | 07:38 AM
Thumper's Avatar
LAZN, for you i corrected my grammer errors, i guess i just picked up on the original posts spelling and ran with it.
My comments were 100% directed toward "Off-Throttle" Engine Brake.
Old Jun 16, 2007 | 08:48 PM
Raise your idle speed to 1500-2000 and you'll have less engine braking.
Old Jun 16, 2007 | 09:44 PM
Chitownson's Avatar
Chitownson is on a distinguished road
Engine Braking
I like the engine braking; that's part of the reason I ride the superhawk instead of some soul-less inline 4 appliance. I can ride twisty roads for miles without the frustrating shifting frenzy. I have friends who ride ducati 900 SS's and I can keep up with them in the curves until they turn it up past 9/10th. (I noticed once I adjsuted my TPS to the lower end of factory specs, the power delivery is much smoother and I can power into turns with more throttle and better control) In the straightaways, I'll take the v-twin's torque & horsepower anyday.
speedkelly@aol.com
Jul 25, 2011 09:35 PM
peterdamian2000
Jun 30, 2009 09:48 PM
tapatio
Mar 23, 2009 01:53 PM
seb421
Mar 18, 2009 04:54 AM
senecagreen
Dec 15, 2006 03:55 PM
