Engine Breaking SuperHawk vs Ducati SS
Just had a flash back to the Ducati 750SS that was in the stable a few years ago. I recall the bike had close to zero engine breaking. The SuperHawk has a lot of engine breaking, is there a difference in flywheel inertia? What gives?
It is nearly impossible to coast on a SuperHawk without instant engine brake and deceleration of coasting speed in a quick manner.
I've tried a 916 and as far as I can remember it was similar. Looking at the TL/SV1000 the seem to behave the same way.
SS750 may have lower compression. Air cooled, low power engine, SV650 is a much smaller engine.
Hard Engine braking is something you get when you buy a large twin.
The superhawk has very little engine breaking if you replace the CCT's, that really is the main cause of dead engines..
But it will still have lots of engine braking, as will any high compression large displacement engine.
[QUOTE=lazn;56226]The superhawk has very little engine breaking if you replace the CCT's, that really is the main cause of dead engines..
QUOTE]
Humm i had Honda replace the original CCT under warranty and then i recently replaced my Honda CCT with the APE CCT's and i noticed no difference in engine brake.
I don't see how the CCT would have anything at all to do with engine brake, its all piston compression and clutch as far as i can tell.
QUOTE]
Humm i had Honda replace the original CCT under warranty and then i recently replaced my Honda CCT with the APE CCT's and i noticed no difference in engine break.
I don't see how the CCT would have anything at all to do with engine break, its all piston compression and clutch as far as i can tell.
I just bought a Ducati ST3 and it doesn't have anything like the SH in engine braking. I thought there was somthing wroung with it. I like the SH much better for this characteristic! However the Duck is a better sport tourer for longer distance.
My comments were 100% directed toward "Off-Throttle" Engine Brake.
Engine Braking
I like the engine braking; that's part of the reason I ride the superhawk instead of some soul-less inline 4 appliance. I can ride twisty roads for miles without the frustrating shifting frenzy. I have friends who ride ducati 900 SS's and I can keep up with them in the curves until they turn it up past 9/10th. (I noticed once I adjsuted my TPS to the lower end of factory specs, the power delivery is much smoother and I can power into turns with more throttle and better control) In the straightaways, I'll take the v-twin's torque & horsepower anyday.
speedkelly@aol.com
Jul 25, 2011 09:35 PM
seb421
Mar 18, 2009 04:54 AM
