Electrical problem ... Ignition?
Old May 27, 2010 | 03:31 PM
josiahbattaglia's Avatar
josiahbattaglia is on a distinguished road
I have an 02 superhawk and the other day when I went to start it I just lost juice. I am trying to diagnose: I have 12v going into the ignition but when it's on, only 5v-6v coming out. If I activate the engine kill switch it's about 7v coming out. Is this normal? I thought I should get 12v out. I don't have anything coming our of the ignition going to the fan motor.
Please Help!
Old May 27, 2010 | 03:44 PM
What has the fan motor got to do with anything?
Have you started with the obvious? checking all the fuses, including the 30A main fuse which sits underneath the rear bodywork... Need to remove that to get to it...
Old May 27, 2010 | 06:37 PM
Stevebis1's Avatar
After you check the fuses, load test the battery. After my recent experience I'd bet your battery is fried.
Easier to check the charging system if the bike is running so charge the battery if it will take a charge;pick up a new one if it won't
Old May 28, 2010 | 12:02 PM
PUSHrod's Avatar
two dead cells. and while you're at it check the output of the VR, you could be cooking batteries.
Old May 28, 2010 | 01:00 PM
Hell I'm still trying to figure out what the base problem is. Did it crank and not start, no cranking at all......or did the fan just not turn on.....
lazn
Oct 11, 2009 12:06 AM
mcbrien
Nov 12, 2007 10:26 PM
elijahawk
Oct 13, 2007 03:56 PM
redman
Jul 24, 2007 10:16 PM
jagermonster
Jun 14, 2007 06:35 PM
