early vs late model fuel sending unit
Old Jul 3, 2012 | 09:14 PM
GTS's Avatar
GTS
Seasoned tech
I'm working on getting the parts together for the late model gauge swap. Looking on ebay there are a ton of early model fuel sending units. However there aren't any late model ones. There is one listed as '97-'05 and when asked the guy said he didn't know what year it came off of. Any way to tell by looking at it if it's an early or late model?
Old Jul 3, 2012 | 09:45 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
If the arm pivots and has a grey big plastic float its the newer... if its a fixed post with a wire going around it to a shiny cylinder its the older...
Old Jul 3, 2012 | 09:49 PM
maniac2313's Avatar
Ive done this swap and have mixed feelings about it...
Old Jul 3, 2012 | 09:59 PM
GTS's Avatar
GTS
Seasoned tech
OK so the later one doesn't have the wire wrapped around the arm at all? Then the one in question is an older one. Why do you have mixed feelings about the swap?
Old Jul 3, 2012 | 10:13 PM
maniac2313's Avatar
Im still getting used to it... speedo is kind of hard to read without modifying the older tank or switching it the fuel guage doesnt read correctly... the rest of the digital part is cool and the tach is nice...
Old Jul 4, 2012 | 10:29 AM
GTS's Avatar
GTS
Seasoned tech
Any reason you can't just tweek the wire the float is on to adjust it's accuracy?
Also I think you missed my last question. So does the later model sending unit not have the wire wrapped around the float arm at all?
Old Jul 4, 2012 | 11:21 AM
BeerHunter's Avatar
Slacker
ebay.com 97-05 Superhawk-VTR1000 Sending
If this is the one you are talking about, it is an early model unit. The little cylinder at the end of the wires is the reserve sensor, and I do not believe that the newer units have this part. But there is no float on this ebay unit anyway.
EDIT: The newer type should not have any wires on the arm.
Old Jul 4, 2012 | 12:12 PM
Just order it from ronayers new. Not too pricey. I recently did a similar swap but used a CBR600RR gauge. Big digital speedo, digitlal everything. 12hr clock.
NOTE. The rubber sealing ring on the 1st gen is a different size to the 2nd one.
The 1st gen it a low fuel sensor. The 2nd gen is a floating arm like in a toilet. NO SIMILARITIES. A gen1 will never send level unless you rebuild it with a float like I did but its next to impossible.
Old Jul 4, 2012 | 01:43 PM
GTS's Avatar
GTS
Seasoned tech
So doing some digging I found some pics of the two sensors. So now I know what I'm looking for. Looked it up on Hondapartsline.com and found it's only $44 so I'll probably just order one. I was hoping ot have one shipped out right away but they say they don't ship for 6-12 days which makes me think they don't have much in stock but actually order it from Honda, then ship it out. I'll check the other site you mentioned. If anyone has one they can ship out right away that'd be awesome. I'm just trying to get this mod done before my 5 day ride I'm leaving for early next week.
Old Jul 4, 2012 | 04:53 PM
That is a very ambitous time frame. Have you got the dash working for speed and tach yet? Temp? (2 diff temp sensors).
You better get crackin.
Old Jul 4, 2012 | 06:36 PM
maniac2313's Avatar
Its a simple swap everything is pretty much color coded theres 1 wire from the bike side that isnt used for the kick stand light the 98 has that the newer doesn't...
Old Jul 5, 2012 | 02:38 AM
GTS's Avatar
GTS
Seasoned tech
Yeah I know it's a tight time frame. I've got the late model wire harness coming and it's supposed to be here on Friday, I've got the gauge cluster coming and it's supposed to be here Thursday. I won't do the swap before the ride if I can't get the fuel level sensor in time. But I don't care as much about the temp sensor. I did find one in a complete housing on ebay for like $7 plus $13 shipping which is a WHOLE lot better than the $35ish for just the sensor new.
But as I said if anyone has these and would be willing to throw them in a flat rate shipping box right away I'd be greatly appreciative!
Old Jul 5, 2012 | 05:34 AM
maniac2313's Avatar
Make sure you use good thread sealant for the temp sender if you dont it will leak...
Old Jul 5, 2012 | 09:53 AM
GTS's Avatar
GTS
Seasoned tech
Yeah I have some liquid sealant that I like to use. That way it still gets a good contact with the housing for a good ground.
Brian D'Antonio
Jul 18, 2013 10:33 AM
102dals
Oct 11, 2009 05:43 AM
KindredGhost
Jul 17, 2008 11:55 PM
Verne
Feb 16, 2008 07:03 PM
Kitch
Apr 25, 2007 02:31 AM
