dynojet kit installed but not running need help
Old May 7, 2006 | 07:04 PM
ericbrinton's Avatar
ericbrinton
OK so I installed my dynojet kit today and im pretty sure everything is hooked up right and back in place but im not getting fuel from the tank into the lines. I switched the petcock to off when i removed the tank and turned it back on once i had it all hooked up and still nothing.. theres no indicator like an arrow pointing to off or on so i have tried it both positions several times. Can anyone help me and give me some ideas why im not getting fuel from the tank. I poured some gas down the fuel lines and got thebike running but once that ran out i was done.. its a full tank of gas and i have checked the lines and still nothing... any suggestions would be great
the only thing i can think of is that i missed a vacuum line but i swear they are all plugged in
Old May 7, 2006 | 07:40 PM
bluevtr's Avatar
bluevtr
seems like I read a similar question a few weeks ago. If I remember right, the problem is that it is a vacuum petcock, so you didn't need to turn it off in the first place, and now you need to fill the lines. If it cranks for 15-20 seconds, it should start. If not, it should be a vacuum line or the petcock is in the wrong position.
Old May 7, 2006 | 07:51 PM
ericbrinton
well thanks for the help.. hopefully I can get it working this week when i find some time between work
Old May 7, 2006 | 09:07 PM
superbling's Avatar
Yeah, it's a vacuum activated petcock so you did'nt need to turn it off to remove the lines (only a couple of drips would have come out). Get a service manual if you are going to work on it.
Old May 7, 2006 | 09:13 PM
Brian A's Avatar
Well, lookie here---> https://www.superhawkforum.com/viewtopic.php?t=2510
Old May 16, 2006 | 12:03 PM
ericbrinton
ok so i missed a very small vacuum line and now it runs like a beast.. cant believe i have been riding this thing a year without the jet kit.. what a difference
J Bragg
Feb 4, 2011 06:32 PM
Flashhart
Feb 25, 2010 10:05 AM
EngineNoO9
Feb 17, 2007 03:03 PM
02MONSTERHAWK
Apr 13, 2006 09:34 AM
CNI Dawg
Oct 25, 2005 10:06 PM
