Diaphragm/Vacuum Piston on VTR Carbs
Old Aug 18, 2006 | 09:52 AM
Vincent's Avatar
Vincent
Can someone take a look in the Service Manual at the images of the Diaphragm/Vacuum Piston on pages 5-10 and 5-14 compared to the drawing on page 5-12. When reinstalling this part, do you want the bell to be down over the piston body or turned out towards the cover?
Old Aug 18, 2006 | 10:34 AM
You want this as on 5-10 and 5-14. I have found it much easier to install the slide/diaphragm assembly into the cover first and then installing the two parts together onto the carb. I minimizes the fumble-fu*k that occurs trying to deal with the long spring. Careful, don't pinch the diaphragm. Also, use one hand to install and hold together the ***'y and the other to guide the needle into the main jet.
Old Aug 18, 2006 | 10:42 AM
BeerHunter's Avatar
Slacker
You want the diaphram down. Then drop the piston in slowly just until the diaphram contacts the carb mating surface. Use a finger underneath the piston to hold it in place while you seat the diaphram. You can check the fit first by placing the carb top on without the spring in place, to get a feel for how it should look when it is assembled properly.
Putting it all together along with the loooooong stock spring is a bit of a pain in the *** (here, shorter DJ springs are a god send). Using a pen, pencil, or long screwdriver shank as a guide you can compress the long spring into the cap. This will help you get the cap back on without disturbing the position of the diaphram.
Once the cap is in place , you can then remove your finger from the underside of the piston and commence to installing the screws. This is how I do it. Others here may have different methods that could work as well.
Old Aug 18, 2006 | 10:43 AM
Stumpy's Avatar
Carbs
If you put a very very small amount of KY jelly on slide boot to hold it on carb it is real easy to install. in my opinion just a thought. It works great for me
Old Aug 18, 2006 | 11:20 AM
KY jelly huh? lol Somehow I think I am getting wise to the reason you sign as Stumpy, he he
cheers
Old Aug 18, 2006 | 11:50 AM
kai ju's Avatar
What works for me is to keep the slide at full throttle with a large bottle cap. Insert it into the throttle bore so that supports the slide from underneath.
This keeps both hands free for the spring/cap installation where I follow the same procedure as Beerhunter.
The bottle cap I found that works really well is what comes on the Honda four quart oil containers but anything that just fits in the bore will work.
Don't forget to remove it when you're done.
Kai Ju
Old Aug 7, 2007 | 07:02 AM
camaroguy72's Avatar
camaroguy72 is on a distinguished road
i was thinking about using some glue to hold the diaphragm in place while i put the cap/spring on... i cant get the rear carb to create vacuum and there are no tears in the diaphragm. think i need to seat it first, then install, but the thing needs to like be held in place while i put it together or it just comes out of the lip on the carb. anyone done that?
Old Aug 7, 2007 | 12:52 PM
superbling's Avatar
Kai's bottle cap sounds like a great tip. Hope I remember it next time. Does it have to be Honda brand oil or can I use Mobil 1. What about synthetic? Too early for that? Sorry, couldn't resist.
I put the diaphragm into an umbrella shape (for a lack of a better description) and slowly lower it into the carb until the edges stick into the valley. I use honda's silicone spray to lube the diaphragm which has a slight tacky properties and that helps to hold it in place.
Then add spring and cap together while SLOWLY but deliberately sandwiching it all together. Usually get it right the first or second time.
Old Aug 10, 2007 | 07:04 AM
it seemed to now work.. so i took some gasket maker meant for gasoline, used a thin layer around the edge of the diaphragm. seated it one section at a time, taped it down, let it dry, removed tape, inserted cover/spring. voila. she runs like a charm.
twist
Jan 19, 2013 07:34 PM
3amta3
Jun 19, 2011 06:13 PM
uchi
Sep 20, 2010 08:54 PM
pwolski
Feb 2, 2010 07:29 AM
jmpovh
Dec 15, 2008 06:08 AM
