De-PAIRed SH that used to run great
Old Sep 25, 2010 | 05:55 PM
awg13's Avatar
awg13 is on a distinguished road
So over the past few months I have been working on my SH and finally got it running well. Replaced plugs, filters (stock), cleaned carbs and set needles (dynojet), and de-paired. The bike has ran great for the past 5 weeks or so and now it it is starting to run progressively worse. Backfire on decel, worse than it used to before the pair removal, not idling at a steady rpm and the occasional carb fart. I am thinking that the carbs are dirty again, but before I rip them apart, I thought I would ask if anyone else had this problem. I bought the PAIR plates off of ebay and I flipped the reed around and put the plate over top. Could I have air leaking in by the plates?
Old Sep 25, 2010 | 06:33 PM
bjorn toulouse's Avatar
Destructive Tester
If there was an issue with the PAIR plates you would have exhaust leaking out, not air leaking in.
Rex
Old Sep 25, 2010 | 07:42 PM
Stevebis1's Avatar
Sounds like a possible vacuum leak. I'd check that out first
Old Oct 8, 2010 | 01:44 PM
justinity's Avatar
Über Member
Where is a common place for a vac leak on the SH
Old Oct 8, 2010 | 02:22 PM
In a hose... And no, I'm not making fun of you...
Old Oct 8, 2010 | 02:50 PM
evines's Avatar
The PAIR can't affect performance, so you've got something else going on.
Old Oct 8, 2010 | 05:33 PM
There's not many posts that make me spontaneously laugh. Thanks!
My latest was an exhaust donut that was blown and it was leaking fresh air into the mids before the cans. On decel they were blowing 18" flames. Put in new donuts and it totally went away.
Old Oct 8, 2010 | 07:05 PM
PVLIR?
Old Oct 9, 2010 | 07:51 AM
justinity's Avatar
Über Member
So is the pair valve like a PCV valve on cars?
Cause my rear one was sucking in air bad.
I capped it off now it's running funny like weaker.
Old Oct 9, 2010 | 08:16 AM
The PAIR is for injecting oxygenated air into the exhaust gasses to reduce emissions by igniting unburnt fuel, making it impossible to get reliable data on a dyno or wideband... In stock form it makes for backfiring, and makes it hard to get a decent setup, but unless you change stuff, a leak into the exhaust in this way should not affect performance in any significant way... The setup you have isn't affected...
You really should lift those caps and check that the reed valves are inversed if it was sucking in air...
Old Oct 9, 2010 | 10:02 AM
justinity's Avatar
Über Member
So from stock they should be sucking in air?
Old Oct 9, 2010 | 10:17 AM
justinity's Avatar
Über Member
Originally Posted by lazn
PVLIR?
Wait what is a PVLIR?
The answer is yes, but it's also a case of acutely oversimplifying things...
The whole system consists of a bunch of hoses, a vaccum bell and reed valves under those covers to regulate how and when the air is sucked into the exhaust gasses... If you don't know how that operates, the information that they "suck air" is completely useless for diagnosing anything...
When you do remove the PAIR system, like has been done on your bike, they should be blocked, no air going anywhere... The "cheap" solution is to rip out the hoses, plug the hole in the airbox bottom up, flip the reed valves under the covers over and block them like with the black cap (referencing your other thread)... The good solution is to replace the covers with a blank aluminium plate, sealing the hole completely...
Old Oct 9, 2010 | 10:25 AM
You know, a good way of making people think you are smarter than the average bear is to use search... It gives excellent answers to questions like that...
Or you could like me, open your mouth and reveal without a doubt, to the whole world that you haven't got the sense to be quiet...
Old Oct 9, 2010 | 11:20 AM
justinity's Avatar
Über Member
I Don't have time to search I want to DW.
Old Oct 9, 2010 | 11:21 AM
justinity's Avatar
Über Member
I have to take some pictures I will be back
jerryh
May 11, 2014 09:33 PM
mfast1
Aug 27, 2008 12:08 PM
cliby
Mar 30, 2007 11:57 PM
cb21983
Mar 26, 2007 01:05 PM
vtrlvr
Feb 8, 2007 07:55 PM
