cough at 3500RPM
Old Apr 18, 2013 | 08:44 AM
twist's Avatar
cough at 3500RPM
I've been following other threads on carburetor issues hoping to glean some information to an issue I've had for a while. The problem: the bike "coughs" even after warm up at about 3500 RPM in 2nd gear. The symptom arrived after I removed the PAIR system. I've gone back over everything several times looking for mistakes but everything is where it's supposed to be. I've balanced the carburetors carefully, adjusted the TPS to 490 ohms and checked fuel hoses and vacuum hoses. I did hawks carburetor enhancement, #48 pilot jets, remove shim from front carb needle and epoxy one lift hole on the front slide. I realize I need to play with the shims to get best performance but the "cough" has not gone away. It's like a backfire through the carbs, I can hear it under the tank in the air box. What next?
Old Apr 18, 2013 | 08:47 AM
It's time to use the choke as your trouble shooting tool. Crack it open slightly, do the bike run better or worse?
If better, you're lean and you need to raise the needles a shim or open the pilots 1\4-1\2 turns.
If worse, you're rich and you either need to drop the needles or close the pilots a little.
Old Apr 18, 2013 | 09:19 AM
twist's Avatar
the choke causes the bike to run worse. So the pilots are too large? Drop the front needle clip or remove shim from rear carb? Adjust air mix screw to get better mix?
Old Apr 18, 2013 | 09:27 AM
twist's Avatar
I should have read your post better, I see that adjustment of the air mixture screw IS the adjustment to the pilot, doh!
Old Apr 18, 2013 | 09:34 AM
The easiest would be to turn the pilot screws in 1\2 turn and see how the bike runs......
Old Apr 18, 2013 | 10:14 AM
It's actually a fuel mixture screw on these carbs. Turing it in= less fuel. This adjustment affects the mixture of fuel going into the pilots, which are the heaviest influence on the lower RPM's. Adjusting the needles doesn't do much until you're in the mid-higher rpm's when the slides open.
Old Apr 18, 2013 | 10:38 AM
zxbud's Avatar
Cough
If it's a backfire into the airbox then logically the intake valve is still open when it occurs which may mean preignition or retarded intake timing. When did it start doing this?
twist's Avatar
got it! Now I need only follow up on my intention to find an easier way to get to those screws while the bike is running. My experience is limited to Mikuni TM 38 flat slides, those are very easy to adjust and not as finicky. So far, my experience with the carburetors on the VTR is, they are touchy to very slight changes and difficult to balance perfectly. That's probably just me tho.
Old Apr 18, 2013 | 10:40 AM
twist's Avatar
seems to me that it began just after I removed the PAIR system. It's a "cough" but it sounds and feels like it's coming through the air box.
Old Apr 18, 2013 | 01:40 PM
WhOrD's Avatar
WhOrD is on a distinguished road
I have a stuttering issue in the same RPM area I have been trying to resolve since reverting back to an almost stock setup.
I had some carb hicups but they were resolved. I am moving forward with shimming the needles to be richer as suggested in my "Carb Fine Tuning thread". Are you also having popping on Decel?
I have not been able to adjust Idle Mixture screws while the bike is running due to the location and my lack of the CRAZY TOOLS REQUIRED!.... ^.^
Step by step, week by week, eventually it will run perfect and then I'll post the bike on Cragslist HAHAHA....just playing.
Old Apr 18, 2013 | 01:57 PM
If it makes you feel any better I had my carbs off yesterday to do a pilot screw adj. The last tweak to get things right again after changing velocity stacks.
So while it can be a pain the reward is worth the effort IMHO
Old Apr 18, 2013 | 02:10 PM
WhOrD's Avatar
Wait a second,
As the Chuck Norris of carbs, I thought you just stared them into perfection........whats with this "removal" nonsense?
Old Apr 18, 2013 | 02:28 PM
Well my pilot tool was in the tool box that walked away a few years back with most of my "special" tools in it.....
and it is one that just hasn't been replaced yet.
Besides you don't have to disconnect anything on the carbs, just pop them out of the boots so its 45mins tops for the whole job.... and that is taking my sweet assed time
Also in case you missed it Carl pointed out a good way to "fine tune" the pilots.
Set the idle @1200RPM or as close as you can get it.
Now "blip" the throttle . you only want the bike to rev to 2K or less and then watch the tach.
Does the needle go directly back to 1200RPM? if so you are good
If the needle hangs up at 1400RPM or so and then settles back down to 1200RPM, then you are lean or open the pilot screw a little bit.
If the needle drops below 1200RPM and then climbs back up, you are rich and need to close the pilot screw
Old Apr 18, 2013 | 03:07 PM
twist's Avatar
I'm very used to adjusting while the bike is running and using my ear, (old air head method), the drop down method seems like a good one. I may have to buy the tool for air mixture if I can't make one I'm happy with. I do get popping on deceleration but not very often, it has to be the right rpm and speed to pop. Where I live now there is no place to work on the bike the way I want to, (secure parking under the building) and the HOA spits up blood when I replace the air filter. I'm on the lookout for a space I can work in once in a while. I've got a lot of tools though, hard to transport on the bike. I manage all the same.
Old Apr 18, 2013 | 03:10 PM
WhOrD's Avatar
Well #!@$, nobody mentioned this to me. I'll verify this when I shim my needles 2nite.
Old Apr 18, 2013 | 04:25 PM
cybercarl's Avatar
I think it was your thread I posted it on LOL
Wow a lot of people playing with/adjusting carbs recently.
zxbud is correct in what he's saying as timing can be an issue but carb coughs can also be a sign of being too lean. The first thing I would do is make sure there are no intake leaks or blowing exhaust gaskets/clamps as this can be an issue as well And in twist's case check over all the PAIR removal and make sure everything is OK there and nothing has been missed. IIRC the PAIR system has a hose that runs to the bottom of the airbox. Did this hole get filled otherwise you may loose a bit of pressure in the airbox.
When putting the 48pilots in did you adjust the fuel screws to compensate for larger pilots. You will probably find with the 48's you will need approx 2.5 turns out on the front and 2.1/4 rear give or take anywhere between 3/8 turn. You would be surprised how much of a difference even 1/8 turn can make. If you had 45's then you would be around 3.5 turns out and if
50's about 1.5 turns. So larger pilot = less and smaller = more.
The pilot jets mainly affect the idle circuit as 7mmore said but it also affects the needle/slide and mains too. It starts heaviest at the bottom (idle circuit) and tapers off to it's smallest at the mains, so the mains get a trickle.
No it's not just you. Dont forget these are the biggest carbs Honda made for the street, so are sensitive to the slightest changes. Dont forget to re-balance again after any carb adjustments.
I use the following for adjusting the fuel/mixture screws.
Carb Tool 90 Degree w/Bits | Motion Pro
superbling
Jan 25, 2008 01:56 PM
98SuperHawk
May 8, 2005 03:03 PM
