cosmetic frame damage repair?
Old Apr 21, 2010 | 04:43 PM
boxdogracing's Avatar
boxdogracing is on a distinguished road
My 98 SH has what appears to be two hammer dents right in the shinny part of the frame below the tank. I know I could fill and paint, but would rather polish the frame. Does anyone know how to fill, so they could be ground and polished out?
Old Apr 22, 2010 | 06:01 AM
superman_006's Avatar
superman_006 is on a distinguished road
There is no easy paint or filler that will polish back out to match.... You could grind on your frame, lay a stack weld (you would need an aluminum welder), grind it down, sand it smo0th then repolish it.
Old Apr 22, 2010 | 07:22 AM
Little_Horse's Avatar
2nd mouse gets the cheese
I would not recommend doing that. Your frame is heat treated so welding on it particularly on the tubing part of the frame will anneal it in what welders call the "heat affected zone." So depending on the size of the dents and their location, and how good of a welder you find to do it could result in a 2 to 3 inch diameter soft spot on your frame. I used to weld bike aluminum bike frames and we would weld them up before heat treatment. If you dropped a tube accidentally it would crush the end or dent the side. Once heated you had to hit it pretty hard with a hammer to get the same result. So heat treatment makes a huge difference. This is why frame damage totals motorcycles. There isn't really any great way to fix it.
Old Apr 22, 2010 | 02:48 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
In Australia, damage like that would mean an automatic statutary write off - compliance plate removed so that the bike can never be repaired and re-registered. (for exactly the reasons outlined by cornandp)
Old Apr 22, 2010 | 02:54 PM
Same here, as long as it's reported or when it comes in for the semi-annual testing... But it's entirely possible that it wasn't in this case reported in any way...
Old Apr 22, 2010 | 03:24 PM
there is no law I am familiar with that says that in the US for us. If it was reported though the bike would be a total, and would then have a branded title. The dent left alone doesn't inherently mean the bike is unsafe. I would just suggest filling it in and painting it if you can't stand the way it looks. I have a paint I use that looks exactly like the cast aluminum bits if that is your cup of tea.
Old Apr 22, 2010 | 04:49 PM
Right now there are small stickers covering them looks O.K. But this is NOT crash damage just superficial like a pissed off girlfriend hit it (there was a matching dent in the tank) just half moon maybe 1/64" deep, just can't polish as they would stick out. So I can't understand how you guys say it should be totaled. New bike, one hammer whak, parts bike???
Old Apr 22, 2010 | 05:17 PM
no I didn't say it should not be used, I said it would be totaled because it would. An insurance company would look at the frame damage the figure the cost to replace it, and all the labor, so it would total the bike easy. Thats all you can ride it with no issue but if you where to try and weld fill it in I would not trust it anymore.
Old Apr 23, 2010 | 09:28 PM
hondavtr1000sp2's Avatar
I painted one side of my frame about a year ago, these photo's were taken today, sorry they are not the best pics they were taken in under ground car park. I sanded & used rattle spray cans, under coat,then matt aluminium, then clear gloss on the front part of the frame. You wouldnt pick it was painted unless you knew. Cost $15. $5 per can.
Attached Thumbnails cosmetic frame damage repair?-dscf3195a.jpg   cosmetic frame damage repair?-dscf3194a.jpg
Old Apr 24, 2010 | 12:14 AM
assuming were talking about a ding and not a buckle
i wasnt saying to grind a hole in the frame.... simply scuff it up where its dented the weld right on top of the ding.....using the aluminum from the spool gun like body filler.
then use a DA to smooth your weld down ........ and repolish
BTW... it would be stronger right where the weld is.
On the bike before my superhawk i weld the front brake lever back together and polished it. Never once thought that the handle would come apart ..... and you couldnt tell where my weld was.
Old Apr 24, 2010 | 02:33 AM
Yes and No... Word of caution here...
Right where the weld is it would indeed be stronger with more material at the right hardness because of the weld...
But an inch or so (possibly larger) in a circle around the weld, where you only have the original material, now affected with heat from welding it will be severely weakened just like corn said...
Exactly how much you will never know until you either hit it with a hammer to know (yeah, like you will that right?) or until it causes an accident...
I'd leave well enough alone and just use filler and paint...
dpg23
Jan 17, 2011 06:06 AM
HondaJim
Jul 26, 2008 09:19 AM
Blkbird
Mar 28, 2008 01:58 PM
Steve
Jan 27, 2006 12:51 PM
Jason C
Sep 18, 2005 04:08 PM
