Cooling issue
Old Sep 27, 2006 | 06:52 PM
dpenix76's Avatar
dpenix76 is on a distinguished road
Cooling issue
My 98 Hawk will heat up normally,fan will come on when appropriate,doesnt overheat,but when I check the coolant after the bike is cool,it is a tad low and the overflow jug has a little more coolant in it than when I started.Correct me if I am wrong but isn't the coolant that flows into the jug when the system is hot and pressurized supposed to flow back into the radiators when it cools back down?
Old Sep 27, 2006 | 07:28 PM
EngineNoO9's Avatar
not quite... When I have done carb work and disconnect the coolant lines from the carbs there's always fluid in them that gets everywhere. annoys the hell out of me... I'm sure you're fine though
Old Sep 27, 2006 | 11:32 PM
http://www.meziere.com/2005_catalog/31.pdf
...Second paragraph. Sounds as though you may have a bad vacuum check valve. Try cleaning it and operating it by hand. Maybe it just needs some love.
MikeMcW
Aug 20, 2013 07:49 PM
reaper
Sep 2, 2007 09:29 AM
seaton001
Apr 5, 2007 01:54 PM
dpenix76
Mar 29, 2007 09:27 PM
Dave Wicks
Dec 27, 2006 02:21 PM
