Coolant weep hole mess!
Old Sep 24, 2011 | 09:56 PM
msethhunter's Avatar
I am getting a lot of oil out of the weep hole. Oil level is right on par with where it should be, and I don't seem to have an excessive amount of oil in the sir box. PCV system also seems to be functioning as designed. Any thoughts?
P.S. I usually ride fairly hard, and see RPM's from 4500> rev limiter regularly.
Old Sep 25, 2011 | 12:17 AM
franz125's Avatar
franz125 is on a distinguished road
Put new lipseal to waterpump and check engine breather.
Old Sep 25, 2011 | 07:09 AM
comedo's Avatar
What year is your bike? The later ones, from at least 2001 on, had a drainage tube from the weep hole. Is the oil coming from a tube or directly from the weep hole? Usually it's coolant leaking from the weep hole that shows that the water pump seal needs replacing.
Old Sep 25, 2011 | 09:29 AM
It's not coolant, it's oil. I run water and WaterWetter. Mine is a '98. Sound like if they put a drainage tube on there, it was to fix the issue I am having then. It's not a whole ton of oil, just enough to notice and annoy me.
ricoshai
Sep 18, 2014 05:21 PM
standzchop
Jun 11, 2013 10:14 AM
mboe794
Apr 6, 2011 04:40 AM
vtrktm
Sep 23, 2007 06:26 AM
Texassuperhawk
May 13, 2007 10:56 AM
