Coolant contamination?
Old Feb 19, 2012 | 09:23 PM
CrankenFine's Avatar
Dumped all the coolant to replace with new Honda 50/50 coolant. Noticed while draining down that some coolant collected in the curved part of the lower crossing hose where I disconnected it from the right radiator. Could be my imagination, but sure looked like almost microscopic flecks of aluminum were mixed into the coolant there.
I think this is original coolant from 2002 since the PO told me he'd never changed it. Possible break-in residue from the factory build process? Or the water pump break-in?
The bike has no leaks, no overheating issues and the old coolant otherwise looked brand new, ie: no discoloration apparent. The drain hose on the pump weep hole fitting was dry.
Old Feb 19, 2012 | 10:22 PM
Yeah, that's normal. Just buy a couple gallons of distilled, flush it out, and refill. I use the orange long life stuff. Don't get the green. It has silicates in it which will make your water pump mechanical seal **** the bed quickly.
j_frank
Apr 28, 2007 11:40 PM
xecutech
Apr 9, 2007 08:53 PM
EngineNoO9
Oct 20, 2006 09:01 PM
Quebecer
Sep 2, 2006 09:03 PM
faz
Jul 29, 2004 10:58 AM
