Coolant Change - Recommendations?
Old Feb 8, 2008 | 04:08 AM
radbikers's Avatar
MSF RiderCoach
Ok, since I'm pulling the fairing today, I might as well go ahead and do a coolant change. A couple of questions for the gurus:
- The service manual says a 1:1 mix. Is that the best for the SH in warm to hot climates (Tampa)? I ask as I've observed quite a swing in the temperature gauge based on idle/stopped in traffic vs. normal riding.
- Of course the manual specifies Honda HP coolant (or similar spec). What's the consensus on coolants for the SH? Will off-the-shelf, buy-it-at-WalMart stuff work, so I don't have to mortgage one of my wife's bikes?
- I haven't done a coolant change on the SH before, and the manual seems straightforward on the steps, but any tips or issues to watch out for?
Thanks!
Old Feb 8, 2008 | 06:45 AM
RickB's Avatar
I have heard that its a good idea to use distilled water with the antifreeze - any decent brand should work fine... water wetter or a similar additive does seem to help the cooling system work a bit more efficiently.
Thanks!
Old Feb 8, 2008 | 08:40 AM
radbikers's Avatar
MSF RiderCoach
Yeh, I'll be doing the standard 1:1 mix, coolant and distilled water, unless there is a better recommendation..
Old Feb 8, 2008 | 08:53 AM
Hotbrakes's Avatar
On the same subject...
What coolants can be used on the track? They say distilled water only but I think I heard Water Wetter is approved too.
Is Water Wetter sufficient for regular street use too or should I change back to coolant after every trackday?
Old Feb 8, 2008 | 09:50 AM
honda996's Avatar
honda996
I just changed my coolant and after researching on here and the manual, I decided to buy prestone extended life, as it is allegedly free of silicates and other junk. I bought the orange stuff since it said "prestone extended life" as their website had.
Old Feb 8, 2008 | 10:20 AM
Well if you are in a place that never freezes, water + water wetter works best. (track or not) However the first freeze will break things.. So you probably should add some antifreeze, and at the recommended mix for that antifreeze.
Old Feb 8, 2008 | 10:28 AM
Syclone's Avatar
Boosted
I think any of the "extended life" A/F's out there will work, IIRC you want to stay away from the "old" style green ones (with silicates?). I work at a Caterpillar dealer, so I run Cat's extended life coolant.
Old Feb 8, 2008 | 11:44 AM
FL02SupaHawk996's Avatar
Fastest Color
I run straight 15 year old Irish Whiskey in my radiator and never runs hot in Florida!
Old Feb 8, 2008 | 12:57 PM
Death Cattle's Avatar
ive been using 1:1 atifreeze/distilled water for now. im most likely going to switch to engine ice though. i use that in my dirt bike and it works considerably better. that and its a cool blue color. but with engine ice, i compared it to my uncles dirt bike which is the exact same bike but he was using antifreeze/distilled water and mine was noticeably cooler.
Old Feb 8, 2008 | 01:18 PM
motojoe's Avatar
Sexual Daredevil
Engine Ice FTW! I noticed a drop of 30 degrees in temp. My fan doesn't come on as quick as it used to and cycles less.
Old Feb 8, 2008 | 04:16 PM
Killemall's Avatar
What do u guys think of HONDA 50/50 Oem coolant??
Old Feb 8, 2008 | 04:26 PM
twstd99's Avatar
twstd99 is on a distinguished road
engine ice is def the way to go.
Old Feb 8, 2008 | 05:25 PM
j_frank's Avatar
j_frank is on a distinguished road
I did mine last summer and ran the prestone extended life pre-mixed.
I refilled w/ water and emptied the system out twice just to get all the old stuff out.
Old Feb 9, 2008 | 07:22 AM
motojoe's Avatar
Sexual Daredevil
It's no different than any 50/50 out there. Private label that's all.
correll1000
Sep 18, 2011 08:52 PM
Sherm831
May 18, 2010 07:07 PM
Randman
Apr 20, 2006 09:28 PM
NOrrTH
Nov 25, 2005 09:59 AM
faz
Jul 29, 2004 10:58 AM
