Compression Question
Old May 16, 2020 | 01:30 PM
timc's Avatar
timc
Hello all, I have a question on compression. I have my carbs and valve covers off and decided to do a compression check.
Both cylinders are at 120, not sure if I should do something different. The number is even on both but shouldn't it be higher?
Old May 17, 2020 | 01:13 PM
ACE VenTRa's Avatar
Yes indeed, a lot more than 120 would be good. I'll have to refer to the manual when I get a sec, but definitely higher than that. Could be a lot of reasons but the easy quick test is to add some oil to the cylinder then retest. If you have normal compression with a cap full of oil, you likely need a bore/hone/rings. Make sure you have the throttle wide open when cranking.
AV
Old May 17, 2020 | 03:01 PM
YMRacing's Avatar
I don't recall that I've ever had 2 identical compression readings on an engine, even a fresh rebuild. I might suggest that you use a different gauge and run it again. Most automotive places, AutoZone, etc loan them out for free. Not saying that they are the most accurate, but.
Old May 17, 2020 | 08:20 PM
timc's Avatar
timc
Thanks for the response, I will grab another gauge and check it again. The bike runs smooth and very good.
Well see what the new gauge shows.
ProfChaos
Oct 4, 2012 09:14 AM
D VTR RIDER
Apr 23, 2011 09:48 AM
ranchomice
Jan 10, 2011 01:58 PM
3D02
Jun 8, 2006 07:20 AM
spEEdfrEEk
Jul 1, 2004 04:51 AM
