Commpresion help
Old Apr 12, 2011 | 10:28 PM
Tokke's Avatar
Tokke is on a distinguished road
Commpresion help
Hi
My Honda Superhawk(firestorm) has got low compression(4 bar) and the ratio is supposed to be 9.4:1.Can anybody tel me or give me advise what it could be ?
The Bike doesn’t smoke or leak oil and has a flat spot from 6000rpm's to 9000rpm's.
Old Apr 12, 2011 | 10:38 PM
nykuryu's Avatar
nykuryu is on a distinguished road
so you have a reading of about 56 lbs (for us silly americans). first are these readings on a warm motor? yes, put some oil in there and redo test. No, warm up bike first. if you add oil and you get higher readings your pistons rings are probably to blame. if your readings dont really change you may have bad valve seating.
Old Apr 12, 2011 | 10:58 PM
Front cylinder? Rear? Both? Like nykuryu said, add a few drops of oil into your spark plug hole and test compression again. If the rings are bad, the oil will temporarily seal them and the compression will go up. If the oil test doesn't change the compression, then it's the valves or possibly a bad gasket.
Old Apr 13, 2011 | 12:50 AM
Tokke's Avatar
The valves has been tested and it's fine they say.
Old Apr 13, 2011 | 12:52 AM
nykuryu's Avatar
how were they "tested"?only way to really test em is with a compression test or a leakdown test
Old Apr 13, 2011 | 05:22 AM
Tokke's Avatar
They did a compression test and it is fine.
Old Apr 13, 2011 | 08:31 AM
nothing's Avatar
ride it out
It's obviously not fine if your compression is that low! LOL mine were nearly 3x as much.
Old Apr 13, 2011 | 10:27 AM
nykuryu's Avatar
ya your compression reading should be rockin around 169 lbs i think or around 12 bar for you.
lynchie
Apr 23, 2011 01:42 PM
mattvdsande
Mar 16, 2009 11:12 AM
