Commpresion help
Commpresion help
Hi
My Honda Superhawk(firestorm) has got low compression(4 bar) and the ratio is supposed to be 9.4:1.Can anybody tel me or give me advise what it could be ?
The Bike doesn’t smoke or leak oil and has a flat spot from 6000rpm's to 9000rpm's.
so you have a reading of about 56 lbs (for us silly americans). first are these readings on a warm motor? yes, put some oil in there and redo test. No, warm up bike first. if you add oil and you get higher readings your pistons rings are probably to blame. if your readings dont really change you may have bad valve seating.
Front cylinder? Rear? Both? Like nykuryu said, add a few drops of oil into your spark plug hole and test compression again. If the rings are bad, the oil will temporarily seal them and the compression will go up. If the oil test doesn't change the compression, then it's the valves or possibly a bad gasket.
