Coil on cap questions
Old Sep 25, 2014 | 10:41 AM
So before I dig into this mod, does anyone know off the top of their head the minmum stuff you have to remove to do it? I see the rear coil is on the subframe and front is in frame spar. I figure lift tank but front fairing too?
Any insight would help me out, thanks.
Old Sep 25, 2014 | 11:16 AM
Just think of what stuff you need to move to change the spark plugs. However, I did mine when the engine was out of the frame, so I'm just shootin' from the hip here.
Old Sep 25, 2014 | 11:25 AM
Jack Flash's Avatar
Well take off, eh.
For ease of work and less chance of scratching the fairing, you are better off removing left side fairing.
I did this mod last winter while the whole fairing was off. I could see it was simpler this way.
COP : coil on plug
Old Sep 25, 2014 | 12:58 PM
Jack what about the tail & tank. What do think the minimum is? Airbox or no?
Old Sep 25, 2014 | 01:26 PM
NZSpokes's Avatar
I must have small hands, all I did was lift the tank and pull the seat off. Rest was a little fiddly but got there. Took about 2 beers.
Old Sep 25, 2014 | 01:42 PM
Jack Flash's Avatar
Well take off, eh.
Joe, don't worry about airbox. Tank is a must. No choice.
As I said, if you don't want to sctratch anything, and, make it it easier on yourself, then it's preferable to remove side fairing.
To me, this is a no brainer. About 5 minutes of work off/on, and you have space and much less risk of sctraching your fairings. IMHO. :O)
NZSpokes
Jun 3, 2015 05:43 AM
smokinjoe73
Oct 13, 2014 03:47 AM
reaper
Jun 22, 2013 08:53 PM
chemomche
Jan 20, 2013 01:00 AM
chemomche
Apr 21, 2012 06:10 AM
