Clutchless upshifts?
Old Jul 15, 2008 | 02:57 PM
CentralCoaster's Avatar
Do you guys upshift with or without the clutch? Or only over a certain RPM?
I tried doing this today, seems very smooth if I time it right and bump the shifter when I back of the throttle, even as low as 4,000 rpms.
The method I reading by Lee Parks is to keep pressure on the shifter prior to backing off the throttle, but that seems to shift it a little too early and harshly before the engine has a chance to slow down into the next gear.
What about wear and tear on the bike? If it drops right in with the same effort as using the clutch, I don't see how it could harm anything.
Old Jul 15, 2008 | 03:04 PM
Springbubba's Avatar
Uhhhhh..huh.huh..Member..
I use the clutch on 1-2 and 2-3 almost all of the time. I go clutchless after that most of the time.
Old Jul 15, 2008 | 03:06 PM
killer5280's Avatar
Done properly I don't think there's more wear and tear doing clutchless upshifts. I always use the clutch for 1-2 (and it's still kinda rough).
Old Jul 15, 2008 | 03:21 PM
In a car transmission you would be wearing the snycromesh gears shifting without the clutch. Motorcycle trans don't use syncros, but still some wear must occur. I don't see the advantage if you are not on the track.
Old Jul 15, 2008 | 03:22 PM
SuperMike's Avatar
SuperMike is on a distinguished road
I like shifting with out the clutch, and like what has been said it is really smooth if timed properly. I read in a moto mag that it does not hurt anything if done properly. Some of my friends swear that it will wear the lower gears out though. I usually use the clutch for the lower gears.
Old Jul 15, 2008 | 03:26 PM
VTRumble's Avatar
Most of the time I only clutch 1-2, if I'm just cruising around, I'll downshift without the clutch also. It takes some practice but can be done very smoothly .
Old Jul 15, 2008 | 03:33 PM
The bike gears aren't synchronized?
I'll have to experiement with the clutchless downshifts, I hadn't tried that.
I figure whether or not I'm using the clutch I need to learn to match revs properly during shifts to keep it smooth.
Old Jul 15, 2008 | 03:37 PM
RCVTR's Avatar
I normally use the clutch on the street, unless I'm doing a WOT run.
On the track the clutch is a stop and go device. Well, not really. I use it for downshifting and preventing wheel hop when decelerating.
For clutchless upshifts it's kind of like a reverse throttle blip from wide-open. You only drop it a bit. I time it with the shift, rather than preloading the shift lever. You want to be sure the gears are unloaded before the shift happens.
I think it's beter for the transmission than excessively lazy shifts, where you can hear the dogs clunk.
If you watch the on-bike cameras on race bikes, you can see them use the clutch for downshifting, then let it out easily on corner entry.
Old Jul 15, 2008 | 04:13 PM
Syncro gears in a car trans are narrow toothed brass gears that line up with the thicker steel gears. Before syncro transmissions you had to "double clutch" to down shift and come to a COMPLETE STOP before shifting into 1st or it would grind.
I've never had an MC trans apart, but I know they don't have syncros. They use "dogs" to engage gears.
Old Jul 15, 2008 | 07:02 PM
Hotbrakes's Avatar
No clutch here. On the street I usually use it unless I'm going flat out, which is pretty much never. Once I hit 3rd, it stays there.
Old Jul 15, 2008 | 07:20 PM
trinc's Avatar
on the track i use the clutch up & down. the quick motion helps me keep my gear count. .
tim
Old Jul 15, 2008 | 08:01 PM
Death Cattle's Avatar
i use the clutch in every gear no matter what, even when i wheelie. IMO, the clutch is obviously there for a reason, so i use it.
Old Jul 15, 2008 | 08:04 PM
killer5280's Avatar
I use it most of the time, both up and down, but when you're really getting on it clutchless upshifts can be both faster and smoother than when using the clutch.
CANADAVTR
Jun 8, 2010 10:34 PM
Darkone22
Mar 6, 2007 05:45 PM
blupleous
Mar 3, 2007 08:17 PM
