clutch problem?
Old Apr 7, 2006 | 04:14 AM
winder's Avatar
winder
clutch problem?
Hi!
A friend just bought a '98 SH. looks like a nice bike. The bike is very clean and well maintained. Has a few nice mods (Micron slip-ons, well tuned jet-kit, Sharkskinz one piece upper fairing.
The bike goes and rides just fine, 'cept what you try to launch it quickly, it jumps and bucks like the clutch is grabbing and then letting go. If you persist in trying to launch it, it keeps bucking. If you pull in the leaver and stop, it's fine.
It shifts up and down smoothly. Makes no odd noises.
The previous owned ssays he was told it has a "gravity clutch" and this is normal. I've never heard of that before.
Any ideas?
thanks,
winder
Old Apr 7, 2006 | 06:21 AM
winder's Avatar
winder
Re: clutch problem?
i don't know why the happy face? this is not a "funny". (it is my first post on this forum.)
thanks,
w
Old Apr 7, 2006 | 06:31 AM
AZZKIKER's Avatar
It is normal for a hydraulic clutch like the SH to do that under hard acceleration. If the clutch fluid is black, he might wanna change it, it might make a difference. But if it pretty bad, he can invest in stiffer springs.
Old Apr 7, 2006 | 01:48 PM
nfbzike's Avatar
nfbzike
Re: clutch problem?
Maybe fluid would make a difference, mine was like super dark like chocolate so i changed it this morning and was testing to see if it made a difference, needless to say, it made a bit of a difference giving me a better clutch feel then what it used to do. It used to kinda hit all at once. like it would just lock right up. Now its smoother. but it also got me a hefty ticket for a bit of an eccentric wheel lifting launch.
Old Apr 7, 2006 | 02:06 PM
AZZKIKER's Avatar
LOL. Why blame the clutch for your ticket??? It is not the clutch but your brains that got you the ticket.
Old Apr 7, 2006 | 02:26 PM
nfbzike's Avatar
nfbzike
Re: clutch problem?
yah i know, Just funny that the first time i do anything remotely wild on the bike i get a nice ticket. apparently 70 in a 45 falls into the "ludacris speed" category in my town. maybe i should of told him i was on my way to plad and he would of just forgotten about the ticket.
Old Apr 7, 2006 | 03:06 PM
JamieDaugherty's Avatar
I launch mine hard sometimes and never has it ever bucked or kicked. Mine's got 12,000 miles and the original clutch/springs. I've heard of other's having this problem (I think MO mentioned this when they drag tested one in 97) but I'm not sure how widespread it is.
Jamie Daugherty
http://members.iquest.net/~daugherj
Old Apr 7, 2006 | 06:22 PM
jschmidt's Avatar
jschmidt
That sounds like a sign of a burnt clutch. I'd bet if you disassembled it, you'd find the plates to be burnt and scored.
This is even more likely in light of the hoser explanation from the seller.
Old Apr 9, 2006 | 03:16 PM
shayne's Avatar
Re: clutch problem?
Or perhaps the clutch basket is a bit worn. This will cause a shuddering clutch too.
Old Apr 9, 2006 | 09:38 PM
winder's Avatar
winder
Re: clutch problem?
thanks for all the replies.
the fluid looks good; not too dark. may have an air pocket. i'l bleed it out first. see if i get any air.
worn clutch basket sounds likely, too. if nothing obvious in hydraulics i'll take the clucth apart tomorrow night. have been too busy to get to it 'till now.
i'l keep ya posted. thanks.
Old Apr 10, 2006 | 11:50 PM
winder's Avatar
winder
Upon further review....
the clutch fluid did look dark. i decided to change it. bled in some fresh Motul 600RBF. found a large air bubble came out after a few seconds. couldn't start the bike tonight (it is late at night), but it feels better.
tomorrow i'l check it out.
i'l probably change clutch out for my friend, too. after 23,000 miiles, it's time. worn OEM springs could create exactly the symptom we're having.
m
Old Apr 11, 2006 | 07:56 PM
winder's Avatar
winder
Re: clutch problem? SOLVED
changing fluid was the solution! as soon as i took it out i could tell it was better. much smoother action and no grabbing.
Problem Solved!
winderOUT
Old Apr 12, 2006 | 02:51 PM
That's an easy solution! Sometimes it's good to go back to simple maintenance first, then explore more involved solutions after. Happy riding!
Jamie Daugherty
bostonhawk
Sep 1, 2012 08:45 AM
dannyz
Jul 19, 2010 07:21 AM
mill7163
May 7, 2008 04:01 AM
dustinwild
Oct 2, 2007 09:19 AM
fundgh
Jun 8, 2007 02:22 PM
