Clutch lever not actuating.
Old Mar 31, 2026 | 05:09 PM
WallaceWood's Avatar
WallaceWood is on a distinguished road
Over the winter I took the clutch slave cylinder off because the part that was holding it was an aftermarket item I didn't want. I never broke the seal on the hydraulic system and the reservoir level appears to be unchanged. Today I finally got around to installing the stock front sprocket cover and even though there was some resistance screwing the slave cylinder back to the sprocket cover, the clutch lever only has the resistance of the lever return spring and doesn't disengage the clutch at all.
What is it that I did wrong and/or don't understand?
Old Apr 1, 2026 | 04:54 AM
Sometimes this system can be a pain to bleed. There's a trick to preventing what happened to you but too late now. You should be ok with a proper bleed as it probably needs new fluid anyway? If the standard way doesn't work, try reverse bleeding.
Old Apr 1, 2026 | 05:00 AM
But he didn't break the seal on the clutch hydraulic system, Wolvy. Are you thinking having the slave disassembled from the case, relieving the pressure of the push rod allowed air to enter the system?
Old Apr 1, 2026 | 06:38 AM
Correct I didn't crack the system open, which I would have thought made bleeding unnecessary. I'll try bleeding it after work tonight just to be sure.
I was wondering whether it's possible for one of the parts on the other end to become displaced. I don't remember moving the rod but I'm not positive I didnt, either.
Old Apr 1, 2026 | 03:22 PM
I started bleeding at the bottom and then I realized that if the air came in through the reservoir it's was all going to be up by the lever. I cracked open the banjo bolt, some foam came out and it worked great. Yay!
Old Apr 4, 2026 | 06:49 AM
When I remove a clutch slave, I zip-tie the lever to the grip, fully depressed. This moves the pushrod in the master past the little hole and can prevent what happened in this instance.
Old Apr 4, 2026 | 06:56 AM
I will definitely be doing that next time.
Old Apr 4, 2026 | 08:26 AM
Good to know. Kinda sounds familiar now that you say it. Thanks.
mikenap
May 7, 2015 08:37 PM
Highfly
Mar 29, 2012 09:32 AM
trinc
Mar 18, 2009 10:47 PM
speedkelly@aol.com
Jul 31, 2007 01:37 PM
Tempest
Sep 20, 2006 07:35 PM
