Clutch Cover
Old Jul 7, 2012 | 03:17 PM
shanetx's Avatar
shanetx is on a distinguished road
Clutch Cover
Ok, long story short there is a plate inside the clutch cover with a rubber spacer behind it, are these parts required? What are there purpose? Has anyone ever done away with the fin design and plated the entire front? I see the pictures from the guy putting Lexan in place... My cover was destroyed in a wreck and have the ability to cut the fins completly out and plate the front and tig it in place... However i do not want to do the work to find i need the fins. I was planning to set the plate to what would be the farthest outcropped fin.
Old Jul 7, 2012 | 09:41 PM
matt365's Avatar
That rubber plate is just to dampen the clutch noise, Its not really needed.
The fins are just really a design, and serve no real purpose. As long as you have the clearance I can't see why you couldn't just tig over it.
Old Jul 8, 2012 | 12:13 PM
shanetx's Avatar
Thanks, I was under the same impression. I am going to give it a shot. I don't want to drop 225.00 for a new cover from honda! I will tig it and continue my search for a used one! I will post before and after pictures of it. Thanks again.
Old Jul 8, 2012 | 07:46 PM
RWhisen's Avatar
Former Superchicken Owner
Shane where are you located?
Old Jul 10, 2012 | 07:57 PM
shanetx's Avatar
I am located in Houston. I have it done, Looks really good! I helped my welder perform the surgery, so the credit is all his! The pictures are not the best. I need to put oil and coolant in it tomorrow and fire it up.
Attached Thumbnails Clutch Cover-img952493.jpg   Clutch Cover-imag0762.jpg   Clutch Cover-imag0760.jpg
CrickiKaze
Mar 19, 2014 12:06 AM
Crashrat
Oct 11, 2012 08:25 PM
rafbo
Jul 16, 2011 10:24 AM
acarp
Sep 20, 2009 11:14 PM
vtrider
Aug 20, 2008 11:57 AM
