It clicked while replacing the Front CCT
Old Mar 25, 2021 | 02:57 PM
Silverbenji's Avatar
Silverbenji is on a distinguished road
what do I do? I haven't been able to find a post about it and mom not too sure how to fix it. I was hand turning the engine and never turned it on. But it clicked once I started to turn it.
Old May 29, 2021 | 02:36 AM
Relsadld's Avatar
Relsadld is on a distinguished road
Excuse me in case I'm as a rule thick however most likely, if the front chamber is at TDC on the pressure stroke the CCT can be taken out without influencing the tooth file. The chain will remain on the sprockets and not slip any teeth. I don't know that would be the situation on the back chamber as it's more upstanding and the chain may miss the lower sprocket.
snaptube vidmate
Old May 29, 2021 | 03:11 PM
misnblu's Avatar
Adrenalin Junkie
misnblu is on a distinguished road
snaptube vidmate
Really? Another spammer with questionable links at the end of their posts? 🙄🤦‍♂️💩🖕🏻
Old May 29, 2021 | 04:52 PM
Seems the problem that some have is not having the cylinder at TDC of the power stroke. Even then there is a possibility of pressure from the valve springs rotating the cam, though unlikely. That is the reason for zip ties on the cam sprockets.
Not knowing where things are at, pulling the valve covers off for a look would be prudent.
Auron
Jan 12, 2019 05:36 AM
psyclown
Jan 11, 2010 01:10 PM
smittyvtf1
Jun 11, 2009 02:31 PM
Mark S
Jun 18, 2008 07:08 PM
bluesman
Nov 8, 2004 06:26 AM
