Charging system diagnosis help
Old Jul 13, 2007 | 12:24 AM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
So my gauges did the "acting possessed" thing which usually indicates a serious issue with the charging system. I did manage to determine the failure is of the not enough voltage variety, so at least I'm not toasting other electronics.
Here's my question: How do I determine if it's the R/R or the generation system causing the low voltage condition?
Current status: 12.5 volts at the battery, bike off. 13.1ish volts, bike on. 13.7 volts, bike on @ 5k (should be ~14.5(?)).
Should I just replace the R/R (either with Honda OEM or R1 mod, haven't decided which yet), or keep trying to chase down the electrical gremlin?
Old Jul 13, 2007 | 05:46 AM
RickB's Avatar
I haven't heard of many '02s and later with the finned R/R failing but anything is possible... check the output at 2k rpm and make sure the battery connections are clean and tight.
raceruss2003
Jul 6, 2012 12:03 PM
psyclown
Jan 11, 2010 01:10 PM
fishface
Apr 21, 2008 11:58 AM
Montana
Mar 15, 2008 09:02 PM
zenrider
Oct 28, 2007 05:03 AM
